Results 1 to 8 of 8
Thread: can you help identify my heater?
    Jul 2013
    mn
    18
    I purchased a used pool that came with a gas heater. It is a large ruud unit approximately 6 years old that used only a gas connection. There is an on/off switch and temperature dial near the top of the unit. I went to the ruud website and they only have current models shown.
    Should there be a product number on it? If so, where? Any info would be useful as it would apply to installing and proper use.
    Thanks
    18*34 above ground doughboy
    Minnesota
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: can you help identify my heater?
    Welcome to the forum.
    A picture might help. Are you just looking for the manual or is there something specific you need to know?
    Mark
    Jul 2013
    mn
    18
    Thanks, I am hopefully loading a couple pics with this.
    this is used equipment and we have no manuals. Therefore any info on proper use and installation would be helpful. We are starting from scratch with the pool and this heater. All I know is that there was only a gas line run to it.[attachment=0:2sg71msl]20130730_115019.jpg[/attachment:2sg71msl]
    Minnesota
    Jan 2013
    Houston, TX
    1,079
    The door on the front below the controls should come off - there will be a wiring diagram and part number on the inside of the door.
    You may aslo want to search Raypak, they were sold under both brands.
    ... looks like a 206 with the manual controls option to me...
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    mas985's Avatar
    Pleasanton, CA
    11,741
    Looks like this one to me:
    http://www.poolsupplyunlimited.com/best ... QgodYE0A3A
    The manuals are on the right half way down.
    Mark
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    So you bought a pool from someone and they also included the heater? Did they tell you anything about the heater like last time it was used etc?
    This is an older unit which is now the same as Raypak.
    What if any specific questions do you have regarding this unit?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jul 2013
    mn
    18
    The only info I received from prior owner was that it worked (too good) about 4 years ago but he stopped using it because of the cost to operate. I got the cover off and it actually had a Raypak sticker and it looks like it is the 266 with the millivolt power so no additional electrical needed. So my understanding in moving forward is that I should run a 1" line to the install location. The gas line will need to be buried 18". I am trying to contact our gas company to see if they do that or if I need to do it myself. On a related question, does this heater seem appropriate for the pool we are also installing (18X34X4' AGP)?
    Thanks
    Minnesota
    Ft Lauderdale, Florida
    1,455
    Just a matter of how many hours your pump will be running, what temperature you want to maintain, and if you're going to use a solar cover or not.
    You have about 18,360 gallons of water, or 152,388 lbs.
    To raise the water temperature 10 degrees, you need 1,523,880 btus (152,388 lbs x 10 degrees). Since your heater burns 266,000 btus/hr and with an average efficiency of 75%, you're only introducing 199,500 btus. Therefore, 1,523,880/199,500 = 7.6 hrs are needed of heater run time to get the temperature up an additional 10 degrees.
    Here's the impact of the solar cover. If you do NOT use it, you should expect to lose approximately 50% of that heat, or about 4 hrs per day to maintain the 10 degrees increase after the initial heating run. If you use a solar cover, you'll lose approximately 20% of that heat, or a little less than 2 hrs to maintain it.
    Most people will heat the pool on demand, rather than keeping it heated up. If that's the case, then expect for your heater to run at least 7.6 hrs in order to get your pool 10 degrees higher.
    You can make the same calculations for higher temperature increases by replacing the 10 degrees in the first section above, with your desired temperature increase.
    Regarding the gas line size, you're best having your local gas company or authorized pool contractor answer that.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
