Results 1 to 17 of 17
Thread: TF-100 Test results....
    Jul 2013
    Chicago IL
    83
    FC-2.0ppm
    CC-0.25.
    Total Chlorine- 2.25ppm
    TA-130
    CYA-25
    PH-7.2
    15ft round AG pool
    What should i add or subract from water??
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    Jul 2013
    Chicago IL
    83
    Re: TF-100 Test results....
    Using pool calculator , hope its accurate . Thanks
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    I'd probably try and keep that minimum FC number to 3 for safetys sake. Ummmmmm........we don't recommend the Pool Frog. A quick search of this forum will tell you why.
    30,395
    Yeah, I'm with woodyp on the Pool Frog and chlorine. I would also suggest a CYA around 40 ppm for Chicago, then chlorine 3-5 ppm.
    Jul 2013
    Chicago IL
    83
    Yea ..after reading other post i shut this pool frog to 0, not going to reinstall next summer.
    After adding 13oz. of Liquid Chlor. & 12oz. of PH increase according to pool calculator heres what i got:::
    FC- 4.5ppm
    CC- 0.25
    PH- 7.8
    TC- 4.75ppm
    TA-125
    CYA- 25
    Do i need to do anything else??? ..How often should i do the full test??
    Thanx all
    Jul 2013
    Chicago IL
    83
    Thanks for all the help ... What an awesome test kit TF-100 is.
    Butterfly's Avatar
    South Carolina
    10,045
    pool-school/basic_pool_care_schedule
    What is CH?
    Are you using 10ML for testing FC/CC?
    You should probably raise the CYA up to about 40ish.
    You're done SLAMing when:
    Jul 2013
    Chicago IL
    83
    CH test ,in 25ml tube, after adding 20drops of 0010 and 5 drops of 0011, it turned pink. Then it took 12drops of 0012 to turn it from pink slightly blue
    So i guess: 120
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Quote Originally Posted by Rynz
    So i guess: 120
    Remember, you keep adding drops and swirling until the last drop makes no change, and subract that one. But you're probably close.
    Jul 2013
    Chicago IL
    83
    Keep adding 0012 until it dosent get any darker blue?
    For CH test -25ml tube
    Jun 2012
    Howell, NJ
    977
    Something is wrong with that CC number. The test only measures in .2 or .5 ppm increments. How did you get .25?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    30,395
    Yes, with all the drops based tests, you continue to add drops until there is NO further color change, then subtract that last drop that didn't have any effect.
    Jul 2013
    Chicago IL
    83
    For CC test... in 25ml , 2 dippers powder , turned pink . Then took 20 drops of 0871 to turn from pink to clear - 20x0.2=(4) then added 5 drops 0003 ..It took 1 drop to go from barely pink to clear : 1 x 0.2 = 0.04
    FC 4
    CC 0.04
    So 4.4 total chlorine??...did i get this right?
    Jun 2013
    Fallsburg, NY
    258
    No, 1 x 0.2 = 0.2, so TC would be 4.2. Mostly we don't need to see TC if you have a valid FC and CC number, we can add and TC doesn't really tell us anything.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    Jul 2013
    Chicago IL
    83
    Ahhh .. bad math thanx
    Jun 2012
    Howell, NJ
    977
    One other thing, there is no need to use the 25 mL sample when testing for chlorine. Use the 10 mL sample and divide number of drops by 2. There is no need for more than .5 ppm resolution. It will save a lot of reagent.
    John
    Jul 2013
    Chicago IL
    83
    Will do
