Results 1 to 7 of 7
Thread: I keep losing prime
    May 2013
    Ottawa - Ontario
    5
    I keep losing prime
    This problem just cropped up over night, been working fine all year. it is a self priming pump, and has worked perfectly up to this point. Now it takes about 30 seconds to prime and only keeps it for about 1 second then a big burp of air seems to come from somewhere and the process starts over. I have checked all the plugs and O ring, seems ok. doesnt seem to be any blockage, but i dont really know how to confirm that
    20,000 gallons
    In Ground Vinyl, Sand Filter
    Pool is older than 5 years
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: I keep losing prime
    Check for low water level in the skimmer, or a stuck weir.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Where are you seeing the bubbles?
    Have you lubed the o-ring on the pump strainer lid? Use the proper pool lube from the pool store. Other lubes can cause the rubber to harden.
    -- Guy --
    May 2013
    Ottawa - Ontario
    5
    water level was the problem, now i feel like a tard, oh well another crises averted. thanks guys
    20,000 gallons
    Jun 2013
    SpringHill FL
    415
    Lol it happens(what seems obvious to some is not always obvious to all)
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I learned long ago to start with the least expensive part if you are looking to solve a problem. Its the part most likely to fail. Water is pretty cheap.
    -- Guy --
    May 2013
    Ottawa - Ontario
    5
    or free, here in quebexico
    20,000 gallons
