Results 1 to 9 of 9
Thread: Stained concrete? Anything I can do?
    May 2013
    Southern IL
    42
    So, a few weeks ago I posted about some small red circles at the bottom of my pool. I used some Lo N Slo in a sock and it cleaned them right up. Sometime in the last few weeks these spots (shown in picture below) are on my concrete. I'm assuming this came from when I was walking away with the sock some of the chemicals got on the concrete. I could be completely wrong but it seems like it was about that time that we noticed these. I've tried to wash it with a hose and it doesn't come off. I didn't know if there is anything I can do. This concrete is only 2 months old. I've attached some pictures.
    30,200 gallon. IG - 20 by 46". Vinyl liner. Sand filter.
    Pentair Intelliflo Variable Speed Pump.
    Built April/May 2013.
    Empress Royal Spa
    22,553
    Re: Stained concrete? Anything I can do?
    Lo N Slo is acid so if it dripped on the deck it has permanently etched it. About the only thing you can do is acid wash the whole deck, and then it's probably not going to be perfect. You could try power washing it first to see if that helps it.
    May 2013
    Southern IL
    42
    Darn! I was afraid of that. I guess, learn from your mistakes but this was a big one .
    Empress Royal Spa
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Looks likes it is time to stain the deck!
    Sorry to see the spots on your deck. Good luck.
    -- Guy --
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Do you have any interest in acrylic coating or stained concrete?
    chiefwej
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    In a couple years it will be aged enough to disappear.
    Can you feel a difference, or is it just the color?
    Support the site
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    You could try powerwashing the whole area. It won't fix the etching, but it might even out the color.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    That deck is pretty dark looking; I bet those spots will darken up to match pretty quickly.
    Maryland
    18000 gallon plaster pool, Pentair Triton II sand filter, Purex Triton Minimax Plus 300 gas heater, 1.0 HP two-speed Pentair Superflo, Polaris 380
    Caldera Marino hot tub, 360 gallon
