Results 1 to 8 of 8
Thread: Very High CYA Levels
    Jul 2013
    Placentia CA
    5
    30K, IG Fiberglass w/DE Filter
    FC-0, TC-0, pH-7.0, TA-30,CH-230, CYA-300+
    These were the results from the local pool store. They say my best course of action at this point is to drain half the water and start over. Water in CA is very expensive. Is there a better way to get the chemicals in balance?
    3,000 Gallon, kidney shape fiberglass.
    22,549
    Re: Very High CYA Levels
    Even given that we don't trust pool store numbers, I'm afraid that you're going to have to replace a lot more than half of your water.
    Is that CA California or Canada?
    If it's california, Reverse Osmosis might be available to you. It's probably going to be as expensive as replacing the water though.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Welcome!
    While that number is possible, I wouldn't trust it. Pool store tests are notoriously unreliable. And if you live in CA, I wouldn't trust that CH reading, either, since everywhere I've lived, the water is really hard. I would expect that number to be far higher.
    There is no easy way to lower CYA short of draining, unless you live close to Escondido, where there is a reverse osmosis outfit that can filter everything out. However, the pool has to be clear, so....
    What does your water look like?
    And have you read anything in Pool School yet?
    Jun 2012
    Howell, NJ
    977
    The first step is to get the recommended test kit. Assuming CA means California, you would be best off ordering from poolsupplyworld.com. If that number is accurate, and your CYA really is 300, that would mean you have to drain 83% of your water. If RO is available by you, from what I remember it costs around $400.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Donldson's Avatar
    NW Ohio
    2,895
    Welcome to TFP!
    Unfortunately I don't have any better news than the previous replies. I don't trust pool store results, but with CYA tests they are more likely to read too low than too high. You would have to test yourself to be sure but if your CYA is well over 300 you will have to drain some 25k gallons of water or do a reverse osmosis treatment. At this point you would have to keep your chlorine level above 23 for it to have any useful effect.
    So did the pool store tell you why your CYA level is that high? Chlorine tablets (made from trichlor) and some "shock" powders (made from dichlor) add CYA along with the chlorine. Am I correct that you use tablets to chlorinate your pool?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2013
    Placentia CA
    5
    Thanks, I'll do some more research before draining.
    Jul 2013
    Placentia CA
    5
    Using granular chlorine.
    22,549
    Granular cholorine comes in three formulas. Dichlor, Cal-hypo and Trichlor. It's obvious from your CH reading that you're not using Cal-hypo. It's probably Dichlor and that adds 9 ppm of CYA for every 10 ppm of FC you add. That owuld be why your CYA is so high.
