Thread: Daily Testing
    May 2013
    Taylorsville, KY
    27
    Daily Testing
    I am approaching close to one full week with my first pool ever. So far I have been using the BBB method and so far, everything has been great. My question is this, what should I be doing to test my daily chlorine use? Should I be using the test in the blue box (taylor) for the daily and add chlorine based on that? (If it reads 3, add enough bleach to raise it by 2ppm). I have the tf100 test kit by the way. I ask because I'm assuming I'll run out of stuff quick if i'm doing the FAS-DPD chlorine test daily (or twice daily, as I was doing at first).
    24' Round AGP, 13,500 Gallons. 19" Ecco Sand Filter, 1.5 HP ecco pump.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Re: Daily Testing
    Quote Originally Posted by LookBehindYou
    The blue box test will just show you if chlorine is present ..... mine is woefully inaccurate so i do the FAS-DPD test every day or two.... i can do it in no time at all and i prefer the more accurate test.
    The powder that came with my test kit lasted into year 2 and is fairly inexpensive so i wouldn't worry about the cost.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    May 2013
    Taylorsville, KY
    27
    Re: Daily Testing
    Well that's not that bad then. I was thinking I'd run out of the powder in a couple weeks because the container is so small. I'll do the better test daily then.
    30,402
    Re: Daily Testing
    Folks do both.
    While the OTO (blue box) is VERY imprecise, it is quite repeatable in that the shade will stay pretty consistent from day to day if your TC stays consistent. It is a lot more convenient and works OK for many people.
    Others simply like the precision the FAS/DPD drops test provides....there's never any doubt. It's a little slower but very reassuring and I would guess that maybe half the users on here use it exclusively.
    Donldson's Avatar
    NW Ohio
    2,881
    Re: Daily Testing
    Luckily you know how to do it right, so odds are you won't do it wrong. I personally test daily with the k-1000 and 1-2 times a week with the FAS-DPD test. I have gotten to know my pool pretty well and know if the yellow is the wrong shade. The FAS-DPD test confirms my findings and assures me there are no CCs, or will warn me if a problem is creeping up.
    So if you like the idea of doing it daily, then by all means do so! You shouldn't need more than one refill a season, if that.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: Daily Testing
    Like the others have said the OTO test is just a down and dirty test to see if chlorine is present. This site teaches you how to learn YOUR pool. They are all just a little different. Use the FAS/DPD test to get your numbers. After some time you will start to see a trend. You might even get to a point where every other day you need to test and just judge it off the amount of sun or cloud cover you had. Also most use the 10ml sample and one scoop of powder. Your other test you will learn also. I test TA about once every two weeks. My pH is very stable unless I run the fountain. I test that once a week or every two days with the fountain running. Start keeping a log and you will learn your pools needs
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
