Thread: Shotcrete rebound question
    Jul 2013
    Saint Louis, MO
    24
    In almost every picture I see of pool construction, whether it is shotcrete or gunite being shot, I see the walls shot first. The workers are standing on the rebar in the pool floor, and there is always some concrete running down the wall, under the rebar & onto the floor. It is still there when the floor is shot. They just blast the shotcrete floor right on top of it. Is this the "rebound" I always hear about? Should it not be present? If it's so important, why aren't floors shot first so that whatever slides off the walls can just be scraped off? If the walls are shot first (like most builders seem to do), how much of this "run down" should I ask that they pick out from in between rebar & remove?
    ____________________________________________
    18x40 ft shotcrete, 4-8 ft deep. Pebble Sheen finish. Coverstar auto cover. Hayward c4030 filter. Hayward H series 300k BTU. Intelliflo pump. Intellichlor IC40. Pentair Easytouch controls. Dolphin Nautilus robot.
    nuklhed's Avatar
    Jul 2013
    Las Vegas, NV
    47
    Re: Shotcrete rebound question
    This is an excellent question. Most experienced gunite crews understand the mandatory objective of the process is to encapsulate the steel in crete. Yes, it's customary for rebound to simply fall to the bottom of the hole but those guys understand their job is to ensure it accumulates no deeper than the bottom of the bar cage, and the blast when they get there knocks it back and compacts it. That compacting action is part of the process that causes the particles to bond together monolithically, so in this sense rebound is not waste, it becomes part of the cross-section. And you'll probably see the guys lift the cage here and there to raise it up into the fresh product they're applying. In fact, watch to see if they indeed do that. If they're not, and if you see them walking around on enough accumulation to cover the bars, especially if they're just shooting over it, point out what they're doing is not the required practice, and take photos because you may need them. You're getting a substandard job.
    While it's true that the least structural stress is on the bottom of a pool, that's no excuse to simply let the steel down there revert back to oxide over the years.
    23,000g IG plaster, textured ceramic 'mock slate' tile and flagstone cascades. Three levels (upper wading 16" dp, other 3.5-ft slate cascade); two skimmers. New Ultraflex II. Pentair Intelliflo 3hp pump, 4-cartridge Hayward filter. Two other 2 hp Superpump II push water features (jets, cascade). Las Vegas, NV (desert enviro). Water temp: winter avg. 45f, summer avg. 86f. Water service: private well, TDS hard @ 250+pp, pool 770ppm!!
    I have often seen gunite crews shovel out rebound and place it in some portion of the pool that needs filling but is not structural, typically areas that have been over dug.
