Results 1 to 10 of 10
Thread: Where did my CYA go?!~
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    So my pool was low on cyanuric acid...so i bought some today...put it in an old tube sock and tied it extremely tight to the frame of my pool in front of the return. Went to check on it before bed...and its almost totally gone! I have almost 4 cups of CYA in that sock and there is barely any left...i see no holes in the sock and looked very close at the bottom of the pool and couldnt see any granules there. Last time i put this stuff in a sock like this it took forever to dissipate...the the cya acid goblin get me or what?
    Should I even be worried?
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Where did my CYA go?!~
    Is it the same brand of CYA? I find some dissolve much faster than others.
    Mark
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Yup, both of them from wally world...maybe the first one was stale? lol...what is a typical disolve time?
    Taylor K-2006
    Donldson's Avatar
    NW Ohio
    2,892
    Man, if you have a CYA goblin you need to be very careful. They tend to be in league with the leprechauns. I don't mean the happy lucky charms kind, I mean the evil Warwick Davis type!
    Luckily it most likely just dissolved faster than you expected. I have had it dissolve in a few hours before and it showed up on the test later with no problems. No worries! Unless there is a goblin... then significant worries...
    Sleep well tonight
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    I'll give it til next weekend and check my CYA levels...they had gotten pretty low, been hard to keep the chlorine up! thanks!
    Taylor K-2006
    Jul 2012
    Seymour, In
    49
    I recently added 4 lbs in a sock in front of the skimmer and within a few hours( 3 or 4 ), it was pretty much all gone. Mine was purchased at Walmart as well.
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    Butterfly's Avatar
    South Carolina
    10,045
    HTH CYA from WallyWorld gets great reviews. Some even say it is more powdery and dissolves faster.
    Info: is-hth-stabilizer-from-walmart-just-as-good-as-t22451.html
    You're done SLAMing when:
    Jul 2009
    S. California
    157
    I use Leslie's Chlor-Brite granules and can dissolve 1# in a tube sock in about 2 minutes. I just hold it in front of the return and away it goes.
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    30,419
    I don't think that is CYA, that's granular chlorine.
    Donldson's Avatar
    NW Ohio
    2,892
    Yeah, that's dichlor. It will increase your CYA but doesn't need to be put in a sock. You can just slowly pour it in front of a return. Pure CYA takes longer and so needs the sock treatment.
