Thread: Test kit first usage
    I received my test kit yesterday. I have read pool school and the test kit instructions.
    My problem is for chlorine testing it says to use " Chlorine only" graduated vial. I dont see one! There IS a graduated thing but not labeled "Chlorine only".
    Am I missing something?
    45K gal, IG vinyl, Hayward extended cycle DE filter, Hayward pump, SmartPool Robot vacuum cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Test kit first usage
    Welcome!
    What kit do you have? If it's the TF100, there should be two vials. The K-2006 isn't that generous, I don't believe.
    Thank you!
    Sorry, should have mentioned. I have the TFT100.
    Richard320's Avatar
    Jan 2010
    18,988
    Quote Originally Posted by poolmommy
    Thank you!
    There should be two vials. One will have a sticker on it. If not, use the one you have and contact Dave. I'm sure he'll make good on it if you got shorted.
    Thank you again.
    No, Dave sent correctly. I realized I ordered the mini version, TF 50. Must be a last minute decision of mine since in my mind the standard size is firmly planted!
    Ok I am good now!!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,085
    There's no difference in Test Vials. The FAS/DPD tends to darken the tube after awhile, thus the reason they included a separate one just for that test. After some time you may tend to see a difference in the tube, but it won't affect the test results at all.
