Results 1 to 10 of 10
Thread: Culprit for burning eyes?
    Yesterday I had a pool party and everyone was complaining of burning eyes. Here we're my results before the big swim:
    TF-100
    FC 5.0
    C 0 (maybe .5 but I'd guess .25 or lower because test was ever so slightly pink, 1 drop cleared it.)
    TC 5.0 (ish)
    pH 7.2
    TA 60
    CH 470
    CYA 45
    I assumed it was just the pH but I meticulously measured to get 7.2 because the pool is me and it spikes up to 8.2 every two days. I was thinking it might also be the slightly high chlorine but since I had 5 kids and 8 adults swimming, I wanted to make sure there was enough to combat bather load and kids peeing and spitting in the pool. This morning I swam again and my eyes were burning like the dickens. Here we're today's results:
    FC 2.5
    CC .5 or less. Again it was barely pink.
    TC 3
    pH 7.6
    TA 60
    CH 470
    CYA 45
    The pH is ideal and the chlorine was lower so what gives? My pool is blue, sparkly, gorgeous, and clear. It looks amazing but it's frustrating to have burning eyes every swim. Watcha think?
    17,000 inground gunite pool finished June 2013. Pentair variable speed something or another. Polaris cleaner, inline rainbow chlorinator. Using trichlor until CYA reaches 50-60.
    38,475
    Re: Culprit for burning eyes?
    Eye irritation is usually CC or pH. Try the FC and CC test with 25mL ... if the CC is more than 1 drop (0.2) that is likely the issue.
    Is it possible that the high CH could be to blame? It the TA of 60? I added 1 drop to yesterday and today's CC reading but it was ever so slightly pink and 1 drop made it clear again. I'm really reluctant to drain and refill for the high calcium...at least until the swimming season is over. The kids like to swim multiple times per day and I don't want my pump off for a day or two in this heat/full sun.
    38,475
    Doubtful. Do the higher accuracy test I suggested. A CC over 0.2 could irritate.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by Dreampool13
    Nobody complains about burning eyes in my pool, with CH about 900. I swim around underwater with my eyes open and no goggles (to admire the clarity) with no irritation at all.
    I suspect either CC or sunscreen washing off into eyes. That stuff stings about as bad as mosquito repellent!
    38,475
    I do want to also point out that your FC is too low now. So if that happens often, something could be in the water that does not show up the CC test.
    Smykowski's Avatar
    Sep 2011
    3,065
    Sunscreen. Which of your guests slathered on a gallon 30 seconds before jumping in?
    Apr 2015
    Katy, TX
    52
    Hey jblizzle, just curious on this more accurate test... I have had burning eye issues for a couple weeks and I'm trying to figure out why. Numbers are below, and everything seems fine, so I figured I'd try to see if there was a CC issue. This test is a little tough for me anyway, since color vision is not my strong suit, but will have my wife double check the colors for me tomorrow. Question is, do I do the FC/CC test as normal, just with 25 mL of pool water? i.e. 1 scoop of R-0870 powder, each 1 drop of R-0871 now equaling .1FC?
    I did it that way, and after 5 drops of R-0003, it was still clear, so it doesn't appear to have any CC's. With the standard FC test, I got 3, and with the more accurate test I got 2.4, but CC still appears to be 0. I'll double check with another set of eyes tomorrow.
    Anything else here raise a flag for burning eyes? pH can be brought down a bit, but I don't think that would be the issue.
    Thanks, Jeff
    FC 3 (2.4 with 25mL test)
    CC 0
    CH 300
    TA 110
    pH between 7.8 - 8.2
    CYA 30
    Katy (Houston, TX) - 15,000 gallon In Ground free form kidney shaped 30'x15' pool with Pebble surface. Spa - 8' round with waterfall. Hayward Swimclear Cartridge filter (not sure which model though - maybe C3025?). Pleatco replacement cartridges x 4, 1.5HP Hayward Century Pump, Hayward Booster Pump (model 6060). Chlorine tab dispenser, which I won't be using. Polaris cleaner. TF-100.
    38,475
    Why bump a 2 year old thread?
    I meant the FAS-DPD with 25ml water so each drop is 0.2ppm. Sounds like you CC is not a problem.
    High pH could be a problem. Sweat or sunscreen too.
    Apr 2015
    Katy, TX
    52
    Ok thanks, appreciate the reply.
