Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: Crack found in new FB pool!
    May 2013
    austin/texas
    140
    So I was vacuuming pool for the first time a few minutes ago and notice a crack on side of pool. First I thought maybe it was scratch but after diving in it I verified it's a pretty significant crack!!!
    I immediately sent picture to PB and he was very surprised also and freaked out, since he was out here the day before and didn't see anything either. He will have Leisure rep come out to see the crack and determine if it can be repaired (hopefully?) or if pool needs to be replaced (hope not?). I have taken lots of pictures and will wait till tomorrow to see what they say but I am certainly not happy about this at all, since pool was just installed and haven't really even used it since decking and backyard is not complete yet. Thoughts, advice?
    34x15, 17K Fiberglass In-Ground Leisure Morroccan SWG, 1 1/2HP 2 speed SuperfFlo pump, Pentair Intellichlor SWG, Pentair Clean & Clear 320 cartridge filter, Pentair EasyTouch 8 panel, 4 returns, 1 skimmer, Installed August 2013, Fiberstar 3-color LEDs, AquaBot AWD robot cleaner, Pentair Easy Touch 8 Wireless remote.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Crack found in new FB pool!
    Patience and best of luck. How far from the top is it on the side?
    May 2013
    austin/texas
    140
    It's on the deep end next to the wall. It's kinda hard to see on this picture, its where the arrow ends
    Jul 2012
    Herndon, VA
    419
    uh oh
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Jun 2013
    Southwick, MA
    211
    Sorry to hear this, is it leaking water??? I can not imagine how they can fix that and it look New.
    Best of Luck, hopefully it is not as bad as it looks.
    24X44 IG Vinyl Custom Shaped Pool, Starite S7M400 Cartridge Filter, Starite Sumpermax VS Pump, built July 2015, TF-100 Test Kit, Pentair Intellichlor IC40 SWG, NG Starite SR400 Heater, Easytouch with Screen Logic, Magicstream Laminars, Bullfrog A7 Spa
    May 2013
    North East Ohio
    959
    Just in case, do you mean FG - as in Fiberglass pool ? If not, what is a FB pool ?
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    May 2013
    austin/texas
    140
    I looked at it closer with goggles and seems to be the surface gel coat only, as I didn't see any fiberglass threads in the cut. I don't think it's leaking water, but I put a tape mark on it and will check in the morning to see. PB will bring manufacturer out tomorrow to look at it, hopefully he said it's something that can be repaired, after they empty the pool and they will cover water cost. I guess if manufacturer says it's not big issue and can be repaired without affecting the warranty (and puts it in writing also) then I should be ok. Will see how it goes tomorrow.
    May 2013
    austin/texas
    140
    PB came today and took underwater pictures of the crack. He mentioned look like it's only the gel coat and not structural. He is meeting with the FB production manager tomorrow to review and verify. Asked him to get in writing from them that this crack won't affect warranty. He mentioned they have a kit to fix the crack and it doesn't even require to empty the pool. Will post update tomorrow. In the meantime work continued on building the garage and outdoor kitchen area. Will post pictures on my construction post in a while.
    May 2013
    austin/texas
    140
    So FB manufacturer saw the pictures and it will actually require to empty the pool and fix the crack (I thought fixing the crack without emptying the pool sounded a bit weird). It should happen over next couple of days, will post updates/pics when it happens.
    Jul 2012
    Herndon, VA
    419
    What does "FB" stand for?
    38,524
    Based in context, must be fiberglass ... although FG, would make more sense
    May 2013
    austin/texas
    140
    Fiberglass. Thought that's what the standard acronym is
    Hi. Just read your post. Sorry to hear about the crack. How did the repair go? Did Leisure provide written confirmation of the warranty despite the crack? Was it truly only in the gel coat? Finally, and most importantly, did they identify what caused the crack?
    10k gallon fiberglass freeform pool, Paramount SwingJet system, Dolphin DX5 robot, Pentair 48" Tagelus sand filter with glass media, WhisperFlo 1 HP pump, Hayward H200FDN natural gas heater, TF-100 Test Kit, and, of course, Margaritaville Tahiti blender!
    May 2013
    austin/texas
    140
    Repair has not started yet. They will come Thursday to empty the pool and then Friday to repair the crack. I will post updates and pictures
    Aug 2010
    Cincinnati, OHIO
    17
    I've heard Leisure totally did away with their surface gelcoat warranty. Anyone else heard that?
    I emailed them a week ago, but of course no reply. All the research I've been doing the past few years almost just makes we want to skip getting a pool. Seems like quality and customer service just isnt what it should be for the kind of money people are spending.
    Hydraulically mundane 20x40 rectangular polymer (~30K gal.), IntelliFlo VS+SVRS pump, IntelliChlor IC40 SWCG, Pentair CCP520 cartridge filter, LED light, 2xDeck Jets, SR Smith Turbo Twister slide
    May 2013
    austin/texas
    140
    I haven't heard that about gel coat. I know owner is actually coming out to fix the crack and I requested and Leisure will provide a letter stating fixing this crack will not void the warranty on the pool and they stand behind it. Will let you know once they fix it and I have everything in writing as promised. I have to admit so far they have responded very well to this issue.
    Jul 2012
    Herndon, VA
    419
    ...as long as more cracks don't appear.....
    May 2013
    austin/texas
    140
    so pool is now empty and got a big bulge in the middle from all the water that leaked from the crack. As such they will have to break concrete and dig on left side of the pool so they can drain water and repair hole from outside.
    May 2013
    North East Ohio
    959
    Mmmm, I thought you/they said the crack was surface.
    Or did the BULGE issue cause the surface crack...I don't think a leak would cause a bulge in a FG pool.
    Something does not smell right! SORRY!
  20. Back To Top    #20
    May 2013
    austin/texas
    140
    Let me clarify. So crack appeared to be surface but after doing the dye test and marking the pool level it was leak. After emptying the pool last night I noticed the bulge due to all the water that had leaked underneath it. There was no bulge before pool was emptied.
