Results 1 to 9 of 9
Thread: replace union
    Jun 2013
    Plymouth Meeting, PA
    29
    replace union
    Hello - The union on my pump is leaking a good amount of water that i believe is affecting the pressure as well. What is the step by step process to replace this? i am pretty handy but this is my first attempt at replacing pool plumbing.
    Also- you can see a coupling downstream of the pump. A specific question would be where is best to cut this pipe to replace the fittings? should i cut past the coupling or before it?
    25,000 gallons (in-ground plaster pool+spa)
    Hayward DE Filter, 1.5 hp pump, Polaris 3900 Sport Vacuum, Honeywell Heater
    TF-100 Test Kit, Using TroubleFree Method
    Getting the hang of pool ownership....
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: replace union
    No need for that straight line coupler to be there..........may have been in the past. Hacksaw, tape measure, sand paper, pvc glue and cleaner and you're done.
    30,419
    Re: replace union
    I can't see a union in your pic???? Are you talking about the adapter (white) that goes into your pump body?
    Jun 2013
    29
    Re: replace union
    Yes
    Apr 2010
    East Texas
    9,591
    Re: replace union
    That's where a half union needs to be then.
    Jun 2013
    29
    Re: replace union
    Where should I cut the exisitkng pipes?
    Apr 2010
    East Texas
    9,591
    Re: replace union
    On the filter side of that straight line coupler.
    Jun 2013
    29
    Re: replace union
    Ok great. Should I just put another couple in then?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: replace union
    I'd put a full union there instead. You'll thank yourself the first time you need to do any pump maintenance.
