Results 1 to 14 of 14
Thread: NEW IG POOL/ NEW CHEMICALS/ NEW USER
    Folks,,
    The pool builder gave my pool an initial treatment on 7/26. I failed to record the readings..
    I have since been testing since 7/28 using the Taylor K-2006 kit..
    Below are my findings..
    The initial treatment by builder was shock/ stabilizer conditioner/ and a hexaborate water harmonizer.
    My readings on 7/27
    FC .4
    CC 3.2
    PH 7
    ALK 30
    CH 150
    Did not measure CYA
    Added some shock to increase FC and Baking Soda to increase PH..
    Readings on 7/28
    FC 8.8
    CC .8
    PH 7.3
    ALK 70
    CH 180
    CYA 43
    Pump has been running 23 hrs. per day since startup. We had some rain yesterday several times..
    I turned the chlorine feeder down to 1/2, builder had it on max. added 13.3 oz baking soda to increase the PH..
    Am I on the right road? Your help is greatly appreciated.
    Search Houston Pool Build under construction for pics..
    13K IG Pool with Raised Spa
    Jandy E Pump- 2HP Variable Speed
    Jandy CV460 Cartridge Filter
    Jandy LXI 40,000 Heater
    Polaris 9300 Robot
    22,553
    Re: NEW IG POOL/ NEW CHEMICALS/ NEW USER
    With the CYA at almost 50 ppm you need to stop using the tablet feeder and go to liquid chlorine.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    + 1 what Bama said. The baking soda raises TA. Borax raises PH.
    Jeff
    Donldson's Avatar
    NW Ohio
    2,916
    Looks like the water harmonizer is just borates, a lot of people here consider that a positive. As has been mentioned the baking soda will raise your TA, but there's a good chance that is going raise your pH so you may want to just leave it. 7.3 pH is within range. It looks like you are using a 25 ml sample size for your chlorine tests? If so a 10 ml test size will save reagent and 0.5 accuracy is plenty.
    Bama is correct, time to shut off the tablets. You also mentioned using a "shock", do you mean a powder? If so what type of chlorine is it?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    30,431
    For our purposes, baking soda raises TA but, for our purposes,no effect on pH.......making it VERY handy to adjust TA but leave pH alone.
    In probably going to the liquid chlorine method but next season. Am I on the right track with balance for now?
    The shock was a granular type.
    Polaris 9300 Robot
    Donldson's Avatar
    NW Ohio
    2,916
    So far everything looks fine.
    What was the ingredients of the granular 'shock' and are you still using it?
    Your CYA is already on the upper end of the recommended range. If you continue to use tablets you are going to have to watch your CYA regularly and increase your minimum FC as your CYA rises.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,648
    If you're gonna use granular "shock"..(which it ain't).......use cal-hypo some within reason.
    New results.. Feel pretty good about these considering my water isn't a week old yet..
    I added
    FC 5.0
    TC 5.5
    PH 7.6
    TA 90
    CH 340
    CYA 39
    SI 0
    My IPAD ap says to add another 1 lb, 4 oz of trichlor shock to fix my CC.. Your thoughts...
    By the way the app for the ipad is "the pool monitor".. Just if your curious
    Thanks
    Polaris 9300 Robot
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What is the CC ? I don' t see it listed.
    Jeff
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You do not show a cc number. Do you have the fas-dpd kit (not to be confused with the dpd kit) that uses the powder? The K-2006 should have it. Test with that and report the CC.
    CC was .5
    Polaris 9300 Robot
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    CC .5 is ok.
    Jeff
    Donldson's Avatar
    NW Ohio
    2,916
    Quote Originally Posted by CAVJOCK22
    It might be time to consider a new app. The Pool Calculator is available in the app store and is based on the methodology used here. It will never tell you to add trichlor shock, which will raise your CYA. You don't need to worry about 0.5 CC, but if it rises then you should use the SLAM process and bleach to correct it. Your CYA is good, adding too much more could lead to trouble.
