Results 1 to 18 of 18
Thread: Algae help
    Algae help
    In my 3rd day of a first ever SLAM, my water has been clear the entire time, however I had green crud growing on the bottom and cove. Since the first brushing there has been no sign of green, CL level has been kept at 30+, I also have brushed at least twice a day. Today decided to shut down the filter for 1 hour to disassemble and clean, OMG split pea soup oozed out. Filter is now back running with new DE. Could the crud in the filter be causing my OCLT to fail, dropped 8 ppm last night
    AG 9000G vinyl-oval 15 x 24
    Hayward powerflo xl pump
    Hayward perflex DE filter
    TF100
    Wide mouth skimmer
    Direct sunlight all day
    W.PA/OH border
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Algae help
    Yep. It sure can.
    Jeff
    Re: Algae help
    I kinda thought so after I seen what spewed out of the filter housing, with some luck and new DE maybe tonight OCLT will pass, CC is < 0.5
    TF100
    Wide mouth skimmer
    W.PA/OH border
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Algae help
    Be sure to check around & behind any light fixtures as well as the ladder (if you have either of these). Those are also common places for algae to seek refuge. Here's an example...http://www.troublefreepool.com/think...ue-t65957.html
    Re: Algae help
    I do not have lights but do have steps mounted to the deck, we removed them and disassembled what we could and there was green inside the steps, removed all the sand that we could and rinsed and bleached the insides, and added new sand(weight). Failed another OCLT last night dropped 4.5ppm, brushed and recholrinatd this morning, trouble is pool water looks gorgeous.Will attach pic as soon as I figure out how to upload. Thx and any recommendations are very welcome at this point.
    TF100
    Wide mouth skimmer
    W.PA/OH border
    Re: Algae help
    Don't know if this will show
    TF100
    Wide mouth skimmer
    W.PA/OH border
    30,421
    Re: Algae help
    You are very close...keep the faith. Do you still see any visible algae? If so, brush it up into the chlorinated water to get it killed quickly. It may cloud your water a bit but that'll clear up.
    Re: Algae help
    There is no sign of green anywhere that I can see. It just won,t pass a OCLT, all other results are good.
    TF100
    Wide mouth skimmer
    W.PA/OH border
    22,551
    Re: Algae help
    Could you get any bleach inside the handrails on the steps? If not you might need to figure out how to do that.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Algae help
    Check the corners and under the basket of your skimmer. That is another place algae likes to hide.
    30,421
    Re: Algae help
    As you know, the point of the OCLT is to see if there are remaining organics in your water. You have some but I do not think you have far to go at all.
    Re: Algae help
    Thx for the encouragement. Bama I did get bleach into the rails was also able to get a small brush inside. Charlie, I need to look at that again pretty sure we cleaned there, during this marathon I can't remember what or when, except for CL readings, I have been logging those.
    TF100
    Wide mouth skimmer
    W.PA/OH border
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Algae help
    Clearly the filter was the primary source of the problem, but are you sure it's now clean? How about the pump basket and the skimmer basket? If you can't find anything, then a SLAM should eventually get rid of it IF circulation of chlorinated water is good, but I'm concerned with how the filter got so cruddy in the first place. It seems that the chlorinated water isn't getting circulated through the system properly.
    Re: Algae help
    Chem Geek,we disassembled the filter, hosed down the socks and then rinsed them in bleach water, also cleaned inside filter housing and pump basket with bleach water. We did reclean skimmer and basket as Charlie suggested. Recharged the filter with the proper amount of DE, circulation is good. Hopefully this will do it.
    TF100
    Wide mouth skimmer
    W.PA/OH border
    Grand SLAM
    Mod Edit: Please keep all of you posts for the same issue in the same thread. Thanks, linen forum moderator
    I believe we won the battle. Question now is should I maintain 24/7 pump operation and maintain a higher than normal FC level for a few more days or can I resume normal pump time, I do 6 hrs a day, and let FC drop on its own, also should I disassemble and clean out the filter again, just did it on Sun., I am rather paranoid now. Had to reorder R-0871, don't know if I could get 1 more 25+ FC test. Thanks to all
    TF100
    Wide mouth skimmer
    W.PA/OH border
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Algae help
    Just to confirm...have you passed all three "end of shocking criteria" in the SLAM process (also in my sig)? If yes, then you can let your FC drop to normal levels and go back to your regular pump operation. If no, then keep at the SLAM process.
    You should clean your DE filter again when it goes up 25% from the "clean" pressure.
    Re: Algae help
    Yes, CC= 0, My wife had to due the OCLT last night for me due to my work schedule- FC drop < 1 I did FC test when I got home and appears right FC same as yesterday afternoon no chlorine was added, water is crystal clear
    TF100
    Wide mouth skimmer
    W.PA/OH border
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Algae help
