Thread: Intex SF15110 motor problrm
    1.) Is there an easy way to troubleshoot why the motor suddenly stopped working? 2.) Where can I buy a new Intex SF15110? The Intex website says they are out of stock.
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Re: Intex SF15110 motor problrm
    More than likely the bearing are shot. It cost me 5$ on ebay for a new set and a small bit of time changing the bearings. Its not hard but its not for people that have no mechanical skill. I have been working on getting up a tutorial on changing the bearings in the Intex pumps. I have the pics but not the time. Hopefully soon I can get it written up. My kids are hogs and eat up all my time lol but I love the little buggers.
    edit: Was it running louder than usual before it died? When my bearings went it got louder and louder for a few days then just cut out completely and wouldn't do nothing. After replacing the bearings it runs quieter and seems to have way better flow rate.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
    I did not notice it running louder. This is the first season for the motor. It had shut itself off a couple of times. It is in the sun and I thought it may be getting too hot. Could this cause it to go out?
    Also, does anyone know where I can buy one online?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Amazon may have them in stock, check there.
    Your local Walmart may even have it.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    If it's first season it should still be under warranty.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Apr 2013
    South California
    69
    Mine got same symptom. It got louder for awhile now stop working. Opened it to check if it was capacitor or bearing. Now when I turn it on, it hums but the impeller wouldn't turn.
    How does the bearing look like and where to order it?
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
