Thread: Trying to fabricate pvc pipe for caretaker assembly
    Jul 2013
    Mesa, AZ
    15
    I have a caretaker 99 pop-up system. The union between the dome and the filter, where the little filter is housed, has a crack in the upper coupling. The pvc pipe appears to be 2" but the 2 unions I have found at Lowes and HomeDepot are a bit too small for the threaded part. I could buy two of those unions and cut the PVC pipe and attach them at the ends, but was hoping to just create the missing pipe section and have it fit with the other parts.
    Did caretaker come with a "funky" sized threaded union?
    Do the one sold online/at pool stores fit?
    40k Pebble Pool with Spa Spillover
    (2) Hayward Pro-grid 6020 DE filters
    (2) Hayward pumps 1.5 hp, 1.60 sf, 2.4 thp
    Hayward H series
    TF-100 test kit
    Jun 2007
    New Jersey
    653
    Re: Trying to fabricate pvc pipe for caretaker assembly
    It looks like you can get what you need here:
    http://www.infloorpoolparts.com/new-...bly-2inch.html
    If not that one, one of the others listed.
    Union threads are not standard. A Hayward nut half won't normally go on somebody else's threaded half, etc.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Jul 2013
    Mesa, AZ
    15
    I found that site yesterday, luckily they are local and I can walk in with part and see if it fits. Good prices.
    Hayward H series
    TF-100 test kit
    Jul 2013
    Mesa, AZ
    15
    That one fit with old pieces, no more leak.
    Hayward H series
    TF-100 test kit
