Results 1 to 7 of 7
Thread: Advice on new install vinly pool
    Jul 2013
    Mississippi
    17
    Hi to all. Well here goes. Just signed a contract with pool builder for a large lagoon 20x42x30. 6 larimars,raised tanning ledge 14 x 28, pro lologic haward swg Hayward vs pump cartridge filter c425, all 2" pvp piping.
    We have been and have seen what salt can do to its surrounding. So we are very hesitant at installing that system. Should we go ahead and install the system and not use the swg at first and just start with the bbb system and if we can't or don't like it just plug in the swg. Will the c425 filter hold up to the salt water. Also we have open contract between a brick or stone coping but with salt we don't know which way to go. We have about a week to decide on a coping.
    Any options and opions would be appreciated. What do you guys think of the pump setup for this size pool?Thanks in advance. Man I didn't think I would be this nervous about this pool thing but I just don't want to have a bad pool built.
    Large lagoon vinly liner pool with straight wall side with 28x14 raised fiberglass tanning ledge with two 30" spill overs six larimars and four bubblers. 35000gallons.
    2- 1 1/2 hp Hayward tri-stars,pro logic plus t-15 swg, 400000 Hayward natural gas heater, Cartridge filter.
    22,539
    Re: Advice on new install vinly pool
    I might go a little larger on the filter but the pump should be fine. You need to know what size cell they're quoting. You want one 1-1/2 to 3 times the pool size.
    Jul 2013
    Mississippi
    17
    It is up to 40000 gallon swg
    Jul 2013
    Mississippi
    17
    The filter says it is 150 gpm and 72000 gallon turnover in eight hours
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Weather you go with the SWG or not, you will need to start your pool as a normal manually dosed pool. The SWG will not produce enough for start-up.
    Remember, you will need at least 24 hours with pump running for your salt (if you add it) to dissolve and mix before you can turn on the SWG. Time enough for an algae bloom to start.
    Jul 2013
    Mississippi
    17
    Oh ok thank you for that info. What is your thought on the coping concerns
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Either choice on the coping will need to have a good sealer sprayed on, multiple coats before adding the salt to your pool. Mortar and high salt concentrations don't get along very long. The stone and brick would do ok, but at the very least, the mortar should be sealed.
    Brick will wick the salt solution to the mortar, stone not so much. That is why I suggest several coats of sealer over it all. For the walking surfaces, to keep them from being too slick, you can add a clear nonskid spray-on over the sealer.
