Results 1 to 18 of 18
Thread: What would make alkalinity rise naturally??
    Aug 2011
    Northville, Mi
    314
    I have noticed that my alkalinity keeps going up, although slowly in general. The only things I've put in the pool this season are bleach, liquid CYA, muriatic acid, and CoverFree and I've not found anything that indicates it would do that (it advertises as pH neutral). I've put enough acid in the pool to bring the TA down about 20 points or more and have even seen it dip, but it's right back up there to 130.
    Any thoughts from anyone?
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    30,432
    Re: What would make alkalinity rise naturally??
    I see no purpose in the CoverFree, but that's your call.
    I would leave the TA alone.
    If you feel you need to lower it, do so according to the article in Pool School....not just with acid.
    Fill water?
    23,000 IG Plaster pool w/ spa, Pentair FNS Plus 48 DE Filter, Hayward RS1000 Main pump, Polaris booster pump, CPSC48 SWG, Legend pool sweep. Dallas, Texas, Full sun, Taylor K-2006
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Is the coverfree one of those liquid solar heating chem's ?
    Jeff
    Butterfly's Avatar
    South Carolina
    10,045
    Did you test the TA of your fill water?
    You're done SLAMing when:
    To elaborate a little on what the others have said, the most likely cause is TA in your fill water. When water evaporates it leaves all of the TA behind. Then when you add water to top off the pool, the fill water brings new TA, which adds to what is already there. Thus, it doesn't take all that high of a fill water TA level to raise the pool TA. Of course this only happens if you get a fair bit of evaporation and add more water to the pool to replace what was lost.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by pwrstrk
    It is marketed as an alternative to a pool cover to help mitigate evaporation. Here's more info on it: http://naturalchemistry.com/Pool_amp...coverfree.html
    doncaruana:
    I agree with duraleigh that the product is unnecessary. I wouldn't use it and I'm not buying the hype that it takes the place of a cover.
    TA is a measure of the water's ability to buffer pH changes. How steady is your pH? If it is fairly steady, I wouldn't fret over the TA. The TA "happy medium" is different for every pool. It may help us if you would post a full set of test results, though.
    Aug 2011
    Northville, Mi
    314
    Quote Originally Posted by Butterfly
    It's been extremely rainy here this summer so there has been zero fill water. All rain water.
    Quote Originally Posted by BoDarville
    Been rising fairly quickly from 7.2 just a couple of weeks ago to 8 this morning.
    FC 4.5
    CC 0
    pH 8
    CYA 60
    TA 130
    CH 80
    It doesn't take the place of a cover, but it does make a difference. A couple of degrees here and there add up when we get a cold snap. Regardless of its effectiveness, I only mentioned it for completeness, in case someone thought it would affect anything.
    From pool school:
    The acid/aeration process to lower TA:
    Add acid to lower your PH to between 7.0 and 7.2 (this also lowers TA)
    Aerate until PH rises to around 7.6 (the only way to raise PH without also raising TA)
    That's exactly what I did so I don't understand the "not just with acid" comment, since that's precisely what pool school calls for. Help me understand what I'm missing please...
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    The plus aeration part I think was what he meant.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    30,432
    Yep.
    Mar 2007
    San Rafael, CA USA
    12,082
    Rain water can raise the TA if the pH of the rain water is high since it can then hold more carbonates (from carbon dioxide in air). Normally though rain is usually acidic and doesn't contribute a measurable amount to TA.
    If you have scale or plaster dissolving (i.e. calcium carbonate being added to the water), then that would raise both the pH and the TA, but your pool is vinyl so that seems unlikely (it's possible to have scale if your calcium is quite high, but again unlikely unless your fill water is high in CH).
    Quote Originally Posted by doncaruana
    liquid CYA
    Liquid CYA is Sodium isocyanurate monohydrate, which will raise the TA some. How much have you added?
    60 ppm of CYA added by liquid CYA will add [edit]23.25[edit] ppm TA.
    Regular cyanuric acid will lower the pH a little, but is TA neutral.
    I wouldn't consider going from 7.2 to 8 over the course of a couple of weeks to be a particularly fast change. How often do you test? It's important to test often enough to prevent the levels from getting out of range.
    Some bleach can have extra hydroxide, which can raise pH and TA a little over time.
    Support the site
    Aug 2011
    Northville, Mi
    314
    Quote Originally Posted by JamesW
    liquid CYA
    60 ppm of CYA added by liquid CYA will add 46.5 ppm TA.
    That's great info and I'll consider it the culprit. Thanks!
    As an aside, wouldn't it be a good idea then to update the pool calculator with that info, specifically in the "Effects of adding chemicals" section for liquid stabilizer?
    I think that I got the calculation wrong. I think that 60 ppm CYA added by liquid CYA should add 23.25ppm TA, not 46.5 ppm.
    Support the site
    Aug 2011
    Northville, Mi
    314
    Regardless of the amount, if it has the effect of raising TA, it seems it should be rolled into the pool calculator...
    Can you share the calculation/info you used in the meantime?
    30,432
    The pool calculator is not owned or managed by anyone on this forum.
    Aug 2011
    Northville, Mi
    314
    I don't use that one anyway. I meant http://www.troublefreepool.com/calc.html
    Mar 2007
    San Rafael, CA USA
    12,082
    Adding pure Cyanuric Acid (CYA) does not change the Total Alkalinity (TA) because the lowering of pH and TA of the weak acid (hydrogen ion) counteracts the rise of TA from the salt (cyanurate ion). However, liquid CYA is sodium cyanurate so increases the TA where for every 10 ppm CYA the TA is increased by 3.88 ppm so James' second calculation is correct.
    Note that this rise in TA is not due to carbonate alkalinity so is not increasing the rate of carbon dioxide outgassing and is not changing the Calcite Saturation Index (CSI) so is not something someone should worry about or adjust lower if your water chemistry was already in balance and you were just increasing the CYA level.
    When you add pure CYA, however, the TA doesn't change upon addition, but the pH is lowered (so carbonate alkalinity is lowered) so depending on how you raise the pH you can affect the CSI. If you let the pH rise from carbon dioxide outgassing, then your CSI will drop relative to where you started, essentially because you've added an acid and aerated (allowed outgassing). In an extreme situation adding 80 ppm pure CYA and having carbon dioxide outgassing bring the pH back to where it was before you added the CYA, the TA doesn't change, but the carbonate alkalinity (at pH 7.5) drops by 24.8 ppm and the CSI drops by 0.16 units. So not a large amount, but not insignificant either.
