Results 1 to 20 of 20
Thread: What to do while away for a week?
    Jun 2010
    Toronto, ON. Canada
    230
    We have had our pool for a month now and may be going away for 5 or 6 days.
    Please can I get help with exactly what we need to do to the pool while away in terms of chems, pumps, swcg, etc?
    Thanks!
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24 Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: What to do while away for a week?
    I see you have a SWG listed so you should be able to maintain FC levels. Test PH and adjust if need be. Test CYA. Is your pump on a timer ?
    Somebody else may have some more advice.
    Jeff
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    It looks like you have a SWG pool. A day or so before you leave, I would do a full series of tests and balance the water as needed while making sure the CYA is in the proper range for a SWG (60-80 ppm). Bottom line: If it is properly chlorinating your pool right now, it should keep doing so while you are gone. It will not know (or care) whether you are in town or not. That's the beauty of a SWG. I would enjoy your vacation and not give it a second thought.
    Butterfly's Avatar
    South Carolina
    10,045
    For more ideas, use the Google Forum Search (upper right) for "vacation".
    You're done SLAMing when:
    Jul 2012
    Saugerties, NY
    447
    I do maintenance on a weekly basis for all of my customers. If the chemicals are in balance and the SWG is working, there is no reason you should have problems in the course of a week. A few things come to mind that I would recommend before leaving it for a week.
    Check the weather forecast. If you are about to see a heat wave, you might want to turn up the SWG.
    Backwash before you go. Chances are your filter can handle more than a week of filtering without a problem, but why chance it.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Jun 2010
    Toronto, ON. Canada
    230
    Thanks for all the replies.
    I currently do not have a timer.
    My pump is running on 240v and SWCG is 120v. How would i hook them up on a timer? Separately?
    Are there many advantages in getting an automation system such as the Hayward prologic?
    Jul 2012
    Saugerties, NY
    447
    In my experience, the automated systems are an expensive way to go. They are usually designed to handle every option out there, and most pools only have what they need to function. They tend to be overkill, and often make things more complicated than they need to be.
    A timer is a great idea. Typically timers are installed so they control both the pump and the salt system. That way your salt system will not try to generate when there is not water circulating. You can certainly get by without one, but they are nice because you don't have to worry about keeping track of how long the pool runs during the day. Once you set the timer, you know.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Jun 2010
    Toronto, ON. Canada
    230
    Quote Originally Posted by TreeFiter
    I agree. I am ok with no crazy automation.
    I have been turning on and off the SWCG and pump, as well as manually adjusting the heater and all.
    So.. I assume I get two timers. One 240v one and another 120v one. Set them up for the same timings and that's it..
    Jul 2012
    Saugerties, NY
    447
    As far as I know, most SWGs can be wired for either 120 or 240v. It might be a good idea to talk to an Electrician. It might be possible to convert the SWG to 240, or there may be a way to wire the timer to control both even at different voltages.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Jun 2010
    Toronto, ON. Canada
    230
    Thanks. Will check. Currently both wired independently. Would be good If I can get both wired together and use one timer and save an outlet too.
    Jun 2010
    Toronto, ON. Canada
    230
    So.. may be going away for just 4 days.
    Is this plan ok?
    1. Test water and add anything to bring it to balance
    2. Backwash
    3. Top up water maybe an extra inch
    4. We are using a solar cover - is it ok to leave it on for 4 days?
    5. I have been running the pump and SWCG about 10 hrs a day (manually). Since I don't have a timer, can I leave the pump (and SWCG) on for the 4 days on V1 at 1200 rpm (low)? What happens if there is a blip in power? Does the pump come back on or will it stay off?
    Thanks!
    Jul 2012
    Saugerties, NY
    447
    I don't have much experience with the Variable Speed pumps, but I would imagine they should behave the same in a power outage as they would if they were unplugged, or the breaker were tripped. You could try that to find out what happens if you have a power outage.
    I don't see any reason you can't leave the pump and SWG running 24/7. You just want to be careful because by changing the run time, you will be adding to the on time of the SWG. SWGs typically run at a percentage. So at 10% they are on 6 minutes out of every hour. At 100% they are on the whole hour. So if you normally run during daylight hours, lets say 12 hours (I run most of my pools from 8am to 8pm), and you run it for 24hrs while you are away, you are running the SWG twice as much and generating twice as much chlorine. Since your solar cover will be on all day every day, you won't see as much loss of FC from sunlight, so you will see FC levels rise. So basically, you will be overchlorinating your pool by running 24/7 at your normal setting. I would probably turn it down to half what it normally runs at if it is going to run 24/7. If your CYA levels are good you will most likely come back to a pool with high FC, which is better than a green one. If that happens, your FC will start to come down on its own once you return to the normal schedule. You can help it along by turning off the SWG for a while. Just keep an eye on the FC levels so that you don't have algae start to grow.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Jun 2010
    Toronto, ON. Canada
    230
    Great. Thanks!
    DO high FC levels cause algae to grow?
    30,421
    Smykowski's Avatar
    Sep 2011
    3,065
    No, but can you explain why you are asking that question?
    Jun 2010
    Toronto, ON. Canada
    230
    Quote Originally Posted by Smykowski
    Treefiter stated that "Just keep an eye on the FC levels so that you don't have algae start to grow."
    I guess I was went under the assumption that if I left my SWCG on too long and FC levels rose too high, I would have algae problems.
    Smykowski's Avatar
    Sep 2011
    3,065
    He was talking about it getting too low. Basically, if your FC gets too high and you have to turn it down or off in order to let the FC come down, watch it close so that it doesn't get too low. Too low and algae will grow.
    Jun 2010
    Toronto, ON. Canada
    230
    Thanks!
    Sep 2012
    Noblesville, IN
    83
    Assuming your Aquarite SWG is the same as ours it can be converted to 240v easily. The diagram is on the inside of the panel door. Our pump and SWG are wired together and turn on and off at the same time. I just put in a timer that controls both.....very simple and convenient.
    32K in ground vinyl pool installed in the early 1990s
    1.5 HP Centurion pump installed in the September of 2012, replaced under warranty in August of 2013
    2.6 SF Hayward sand filter - age unknown but looks pretty new
    Jandy AE-TI heat pump - age unknown but looks new and works great
    Caretaker in-floor cleaning system - works, but not well....on my list of things to work on.
    Aqua-rite SWG - new in about 2006, T-15 cell replaced in summer of 2012
  20. Back To Top    #20
    Jun 2010
    Toronto, ON. Canada
    230
    Quote Originally Posted by mmcgovern
    Thanks. I looked and yes, it can be used at 120v or 240v.... Will change the jumpers and wire it into one plug for both the pump and SWCG.
