Thread: i have a problem with test kits, need advice
    Well, the title says it, the problem is i am partially color blind. I can see colors, but i sometimes have trouble distinguishing between reds/browns , reds/oranges , greens/browns, and blues/purples
    Will this make testing my water hard for me? If so what are my options?
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: i have a problem with test kits, need advice
    This has come up before. It is really going to depend on your level colorblindness. Many of the tests you would be ok with. Some you won't. Check out the post below.
    color-blindness-and-salt-water-testing-digital-solutions-t19479.html
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    TF-100's YouTube Channel
    On their page they show video's of the actuial tests. Give them a watch and see if you can tell the difference in colors. Almost all of them (with the exception of PH) the color change is HUGE. Turning from a green to a red, or a pink to a clear. There's little need to see the difference between red and light red.
