Results 1 to 11 of 11
Thread: How can I get a consistent scoop of the R-0870 DPD powder
    Aug 2011
    Northern California
    15
    Hello,
    I have read through many of the posts and I am in the middle of my first SLAM. I have all the supplies on hand and am testing regularly.
    My question is how can I get a consistent amount of the R-0870 powder for the Chlorine test?
    Some times I get a level scoop, others a heaping scoop., sometimes I get a level scoop but after i dump it in some sticks to the scoop.
    This seems to be the cause to some varied FC tests i am doing. I really need to get this figured out as I think tonight or tomorrow night my pool will likely pass the Overnight Test OFCT(?)
    Mike
    Northern Californio
    18,500 gallons
    Cartridge Filter
    Inground. Pebble Tech, Pentair Variable Speed Pump.
    Jun 2012
    Howell, NJ
    977
    Re: How can I get a consistent scoop of the R-0870 DPD powde
    The amount of powder isn't critical. If you have a few undissolved granules after swirling, you have added enough powder.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You don't want too little powder. Too much doesn't matter. I use a heaping scoop. By the time I'm done with the test everything is usually dissolved.
    I can sometimes tell if the FC level is pretty high in my range by how pink the sample gets.
    Jeff
    Aug 2011
    Northern California
    15
    Great, Thanks.
    I think sometimes I was not getting enought.
    Out to test my pool after an overnight SLAM and OFCT
    Mike
    Mike
    Northern Californio
    18,500 gallons
    Cartridge Filter
    38,369
    If you are at shock level FC, you will certainly want to use extra powder.
    Aug 2011
    Northern California
    15
    Great. I just used 2 heaping scoops and my FC looks about right from the OFCT.
    I am going to watch it today and hopefully it will drop to a more normal level and then I can get an accurate OFCT test, then start testing once a day to establish my chlorine consumption.
    This board is great, hopefully I can answers others questions like you have answered mine.
    What goes around, comes around,
    Mike
    ps. I bought the large refill kits from the TFT Test kit people and the Swirler device, great service, great prices.
    Mike
    Northern Californio
    18,500 gallons
    Cartridge Filter
    38,369
    What is your CYA and FC level now? Usually the OCLT is done up closer to shock level and nit the lower maintenance levels.
    Aug 2011
    Northern California
    15
    My CYA is at 50 (pool gets sun most of the day) and shock level is 22PPM. I am sitting at about 25ppm FC, right now. I have cleaned my filters (cartridge type) and the water looks better than the first day I filled it up.
    Am I good to go for an OFCT tonight? I think I will loose 3~5 PPM during the day today, but have yet to confirm that, and it is cloudy here in Northern CA.
    Appreciate the info!
    Mike
    Mike
    Northern Californio
    18,500 gallons
    Cartridge Filter
    38,369
    Oh. Yeah you should be fine to try the OCLT. When you said you were letting it drop, I thought you were below shock level already.
    Aug 2011
    Northern California
    15
    Thanks Jason.
    I have an 18.5k gallon IG PebbletTech pool, with a Pentair variable speed pump and Pentair cartridge filters. I use a solar cover as well.
    I will let you know how the OFCT goes,
    Mike
    Mike
    Northern Californio
    18,500 gallons
    Cartridge Filter
    30,426
    OCLT (overnight chlorine loss test)
