Results 1 to 9 of 9
Thread: wall popped out of track
    Jun 2011
    Central Iowa
    105
    We just got out liner in and started filling and noticed a 2 ft section of wall popped out of bottom track! We have been trying to get it back in but is causing more of the wall to pop out on either side as we work with it. What do we do? Do we need to take the liner back out or is there a way fix with out sucking the water out and removing liner?
    27' x 54" AG Morada RTR/19,300 gal/ 1hp-2spd Hayward Power-Flo Matrix/Hayward 256T sand filter
    Casey's Avatar
    SW PA
    10,448
    Re: wall popped out of track
    More than likely, your site is NOT level! I just installed today as a DIY and my build went so smooth. The walls never jumped the track. I read my manual several times since March n it states that the #1 reason for walls jumping track is because of an unlevel site.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Take the water out of the liner....
    -- Guy --
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Is the bottom rail sitting flush on the ground in that area ? You might have to drain and take liner out for this.
    Jeff
    May 2013
    Santa Barbara, CA
    10
    I just installed an oval agp, and had a section that was about 1/2" off that caused the wall to jump track. Didnt seem like much until the wind let the wall jump track while still empty.
    With water still in, youll never fix the problem.
    15x30 Sharkline Heritage AGP, 8000 gal
    Pentair SD80 Sand Filter, Pentair 2 speed .75 HP pump
    Self-built July 2013
    BBB (Just bleach) so far
    Jul 2012
    Seymour, In
    49
    Seen that happen to a friend on a 24ft pool last summer. I stopped by to help and found the ground was not level on that side of the pool that was jumping out of the track. Sometimes just using the eyeball to level doesn't work 100%. I would for sure check to make sure the ground is level in the area you are having problems.
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    Jun 2011
    Central Iowa
    105
    The post right near the jumped track is off the ground a little but. They did put some steel in under the bottom brace on top of the block to add support. It does appear the ground was not as level as thought. We used laser level during excavation but apparently missed a spot. It's kind of been a nightmare of a weekend with the wind kicking up unexpectidly Saturday am while trying to install the steel wall. Just not enough manpower and apparently working all day to find we weren't 100% level. Can a round pool take some variation a bit more than an oval?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    The tracks on most AG pools are the same track for all of the round pools a maker manufactures, so the track you have is designed to support the walls on pools with well over 100,000 pounds of water. If the track and wall are not working it indicates to me that your site is not level enough.
    When you leveled the site, did you move dirt from the high side to fill in the low side? Is the post on the low side" where you filled?
    -- Guy --
    Jun 2011
    Central Iowa
    105
    Hi there. We did not do any filling for the inital site prep. Just excavated out the slope to make "level" to the lowest point and sunk in the block to ground level.
    (Vent) - I am so dissapointed. I'm a perfectionist wife to a fault I'm sure and was so excited and thought everything was great. We used lazer level and tried to level the sand as best we could. Tamped 3 times but I think the sand is uneven as well! Both hubby and I are exhaused and had to pull in neighbor to help most of the weekend now to find it's rolly polly. It's a surprise for our kids who are coming home tomorrow night It's about 1/3 full now as husband does not think it will be an issue. "remember I'm the perfectionist!" but the thought of tearing it down to the dirt and doing it all again makes me want to cry.
    (Vent Over)
