Results 1 to 13 of 13
Thread: help neede
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    help neede
    I tested my friend's water today with my Taylor2006 kit. The sample turn red rather than green for the TA level and cya is about 200. No FC at all.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: help neede
    Looks like some water replacement is in need to lower CYA. No FC is not good also. Algae bloom is just waiting. You need chlorine as I assume you know.
    Read the SLAM process.
    Jeff
    Oct 2012
    209
    Re: help neede
    Classic symptoms of Trichlor tab usage (or frog system)....and dichlor shock? They both are acidic and lower TA...as well as raise CYA. Need to do a drain and refill....or multiple partial drains and refills....Then recheck the ALK...adjust with baking soda if needed to at least 80. Go higher if they plan to keep on using tabs, and educate them on the importance of testing their water regularly. Also do they have a heater, do they use copper algaecide, or the frog system?
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: help neede
    Given a CYA of 200 with no FC, if the water is not yet green and/or cloudy, it soon will be. A drain & refill of about 75% is needed to get the CYA down to a preferred range. After the drain & refill, retest and re-balance the water paying primary attention to FC and pH. You may also need to SLAM.
    I would test TA and the other parameters (CYA, CH) so you can note them. If the pH stays relatively stable, I would not fret over the TA. TA is a measure of the water's ability to buffer pH change. It is a fine-tuning type of adjustment.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: help neede
    The PH is really low and causing rashes (or what I think are burns) to the swimmers
    Installed May 2011
    BBB method
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: help neede
    I hope I can talk her into a partial drain and refill
    Installed May 2011
    BBB method
    Donldson's Avatar
    NW Ohio
    2,893
    Re: help neede
    Quote Originally Posted by poolmama67
    Is she doing anything at all about this? Extremely low pH could be helping keep the algae at bay but then people are essentially swimming in vinegar, with the above result. No point working on the pH or TA yet though since she needs to drain well over half of her water to get back to a reasonable CYA level.
    I do hope she listens to you, sounds like someone needs to learn about etiquette. Pretty sure somewhere in Emily Post it says that house guests should not receive rashes from the pool
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: help neede
    Not much choice here. If you have to SLAM, I hope her driveway is tanker friendly because that's how much chlorine you will need
    Jeff
    mmn's Avatar
    Jul 2013
    South Florida
    34
    Re: help neede
    If you can't, she's in for a "shock"!
    Regards
    Michael
    14,288 gal IG freeform Diamondbrite
    Hayward 9002 filter
    3/4 hp Hayward pump
    Barracuda G3 cleaner
    TF-100 test kit
    resurfaced 6/2013
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: help neede
    Well she is ordering the test kit so maybe I have converted another.
    Installed May 2011
    BBB method
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: help neede
    Good job.
    Jeff
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: help neede
    An initial red in the TA test means not only that the TA is zero (or negative), but that the pH is 4.5 or lower. Not only is some water replacement needed to reduce the CYA level, but the pH needs to be raised right away to prevent further damage of pool surfaces and equipment.
    Re: help neede
    I think that it's important to stress to your friend how unsafe that water is. No one should be in that pool until the problems have been corrected.
    Support the site
