Thread: Cloudy again
    Cloudy again
    Here are my test results:
    FC - 21 ( I brought it up this morning to this level. It was at 4)
    TA - 160
    PH - 7.5
    CYA - 40
    CH - 280
    We have had MUCH rain, and I've had to drain several inches after each of these horrible storms in Ohio. The water has been great this summer, up until about 2 weeks ago. It started getting cloudy, and I SLAMMED it. Cleared up for a couple of days, and then back to cloudy. I brought it back up to shock level this morning. Am I doing everything right at this point?
    PH has been all over the place during these storms, but I'm trying hard to keep it adjusted.
    Installed Sept 2008. 18 x 36 Flatback Kidney Radiant, Vinyl liner 25,000 inground, Hayward Max-Flo 1 HP Pool Pump SP2807X10 (runs 24/7) , Hayward Pro-Series High Rate Sand Filter Model #S244T, Hayward Heat Pro, Frog chlorinator is turned off, TF-100 Test kit
    Location is Toronto, Ohio, overlooking the Mighty Ohio River. My river days are done. Sold the boat and Waverunner and now prefer a pool over the river.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Cloudy again
    You need to keep it at shock level until you pass
    1 OCLT. Lose 1ppm or less
    2 CC of 0.5 or less
    3 water is clear
    You probably didn't follow thru correctly. What did you SLAM with ? Liquid chlorine ?
    SLAM. shock level and maintain.
    Jeff
    Re: Cloudy again
    Remember that you can't use the PH test results when the FC level is above 10. Hopefully that PH test was done before your brought up the FC level.
    Your TA is fairly high, which could cause calcium clouding. Calcium clouding is nearly always white clouds, while algae is only rarely white. High TA will also cause the PH to go up when it rains.
    Have you allowed FC to go below 3? If so that is probably the cause of the problem.
    Re: Cloudy again
    I am using Liquid Chlorine to SLAM. I will keep the level up until the water is clear. I did this 2 weeks ago, but hard rains continued last week after I thought I had it under control. 2 inches of rain water in 15 minutes last week. Lots of flooding going on here.
    The PH level yesterday was 7.2. The 7.5 reading today was after I brought the FC level up.
    Is there a way to get the TA down?
    Re: Cloudy again
    BTW - Thank you everyone for your help.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Cloudy again
    Yes,but that's a whole other process. Finish the slam since its started then tackle the TA. Plus you get an inaccurate PH test at high FC levels.
    Jeff
