Thread: Intermatic pool timer
    I have an in ground pool built in 1982 and the intermatic timer motor has finally failed after 31 years.
    The intermatic has the part number E10694 stamped on it. The motor say to replace with WG 430-3.
    When I do a search for that motor I get other results.
    Does anyone know the correct replacement part?
    Is the E10694 a T101,T102 or T104?
    I bought a new T104 but removing that motor did not work to install on my Intermatic mechanism.
    Help please.
    21,000 gallon, 30' round AG pool (new install in 2013)
    Hayward SwimPro SW256T sand filter, Hayward SwimPro Voyager 2HP pump
    Pool Pilot Dig 220 SC-48 SWG
    Taylor K-2006 FAS-DPD test kit
    Re: Intermatic pool timer
    The Intermatic E10694 is not designed to be serviced, you are supposed to replace the entire unit. The T10X series is designed to be serviced, and can have the motor, switch, and case replaced separately.
    Is there a workaround?
    Like I say, I bought a new T104 and my E10694 has an extra trigger doohickey which does not transplant to the T104.
    Is the E10694 still available?
    I called the nice people at Intermatic and they tell me that they still make the replacement motor for the timer. Ordered it today.
