Thread: Chlorine balancing frustration
    ...and if I remember correctly, "shock value" is double your target FC - right??
    28,600 gal, IG vinyl, St. Louis, MO - Installed: 09/2012
    Pump: 1.5 hp Pentair Challenger, Filter: Pentair TR-100 sand, SWG: IntelliChlor (Pentair) Vac: 2-wheel The Pool Cleaner, Test Kit: TFT100 kit, Salt Test: Taylor sodium chloride drop test.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Chlorine balancing frustration
    Quote Originally Posted by Cathy9887
    Well, no. But, it is appx 40% of CYA level, tho.
    pool-school/chlorine_cya_chart_shock
    You're done SLAMing when:
