Results 1 to 11 of 11
Thread: Muriatic acid vs PH Minus
    Hi there,
    This is my second summer with my pool: above ground 24 feet with SWG (AquaTrol).
    I nerver had to add anything so far (last year and this year) to lower my PH, but I may need to do it soon. M'y PH is trying to reach 7.8
    I have read here many time that people put muriatic acid to lower their PH. I don't know nothing about muriatic acid, I had to Google it to know what it is. I have never seen it on the shelve at the pool store neither (maybe they have it, I have never looked for it, I will check next time).
    So, in case I need to lower my PH I bought some PH Minus (powder), does it do the same thing than the muriatic acid everybody is talking about Is adding PH Minus as god as muriatic acid ?
    BIC
    Don
    SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter
    Pentair Intelliflow pump
    Pentair SWG
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Muriatic acid vs PH Minus
    Quote Originally Posted by BIC
    Hi there,
    I have read here many time that people put muriatic acid to lower their PH. I don't know nothing about muriatic acid, I had to Google it to know what it is. I have never seen it on the shelve at the pool store neither.
    BIC
    Probably just more expensive. I'm pretty sure it does the same thing.
    You can find Muratic Acid at the hardware store. But it's probably too late, most pool stores won't let you return chemicals.
    Muriatic acid is less expensive than PH Minus/dry acid. Also, it doesn't add anything you don't want in the pool. Muriatic acid can be annoying to handle though, watch out for the fumes - stay up wind.
    ktdave's Avatar
    Katy, TX
    888
    Some SWG manufacturers recommend using muratic acid instead of sodium bisulfate (pH minus). I forgot the reason.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Guest
    Quote Originally Posted by ktdave
    Some cell plates can be damaged by sulfates created by the use of dry acid (sodium bisulfate).
    Thanks guys for the info. I will take a look at what Goldline (AquaTrol) says about lowering PH with their SWG.
    I will also take a look at muriactic acid next time I go to the stores.
    BIC
    Don
    SW Florida
    Pentair SWG
    Jul 2007
    Rockville, CA
    99
    My local pool store keeps it in the back. If you didn't know to ask for it, you wouldn't know they carried it. The local Home depot only sells the half-strength variety, (It's pink.) and I like to support the local store when I can. And do keep the container at arm's length when pouring. Way harsh.
    20K inground gunite w/ Aqua Logic automation and chlorination Sta-Rite 400 K natural gas heater and cartridge filter 2 HP pump 1.5 HP spa bubbler for spillover spa 1 HP dedicated Letro Legend cleaner
    H2O: two parts Heart and one part Obsession. ~Author Unknown
    In the manual for the aquatrol is says to use muriatic acid to lower the PH. I bough it at Lowes. For some reason the Home Depot by my house does nott carry it. Also a lot of smaller hardware stores carry it like ACE and ACO.
    Patriot Arcadia 15' round 52". Pentair Clean and Clear 100 sqft Cartridge filter, 1HP Optiflow pump, Goldline Aquatrol SWG. 2 - 4'x20' solar panels roof mounted. All rigid PVC plumbing. Resin Solar reel with 8mil Thermo-tex solar cover. 14 x 12 deck.
    Ovation 15'x24'x52'' AG. Pentair System 3 150 SQ foot cartridge filter, 1 1/2 HP pump.
    Guest
    In big box stores and hardware stores it is often near the paint or plaster
    Jun 2007
    Boise Idaho
    58
    Ace hardware has the best prices I have found at 5.99 or closer to 5 if you purchase 4 and ask for the case price. They carry the 31.5% strength.
    __________________________________________
    18x36 inground, sand filter, sta-rite sr400 ng heater
    Jul 2007
    Brisbane, Australia
    874
    We usually carry ~53g drums of 33.3% in stock, just in case anyone wants one
