Results 1 to 8 of 8
Thread: Need some help with basics!!
    Western KY
    36
    I am a new inground pool owner and need some help with the basics. My pool has a liner, sand filter, and is 20,000 gallons. What chemicals should I normally have to add weekly/monthly? How often should I vacume? How many hours per day should I run the filter? Each Time I vacume the water becomes cloudy, what is the cause for this?
    20,000 gal. Vinyl
    1.5 hp pump 300 lb. sand filter.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Start with the stickies. This one should help get you started:
    http://www.troublefreepool.com/viewtopic.php?t=97
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    First, get a good test kit!
    Daily - skim the surface, clean skimmer basket(s), test chlorine, add bleach as needed.
    With a SWG, chemical additions in last 24 hours, or after a storm also test the PH.
    Weekly - vacuum, clean out the pump strainer basket, check water level, run a full set of tests
    As needed - watch filter pressure, backwash (sand, DE) or clean (cartridge) when pressure goes up 10 psi
    Running the pump 10 hours a day is a good default. Keep an eye on your water and if it looks great lower the run time, if it looks bad raise the run time. [[You might want to take a try at guessing the number of gallons per minute (GPM) your pump/filter system moves to see if you can get a better starting point, but that is complex and the appearance of the water is the factor that really matters.]]
    Good Luck!
    East Tennessee
    278
    Re: Need some help with basics!!
    Quote Originally Posted by cateng
    How long has the pool been running?
    Steve
    Echo Canyon II by Artesian Pools, 13.5 KGal AG Round, 22" Artesian Sand Filter 2 hp Artesian pump
    Med Lab Tech for 12 years in E.TN
    Chem testing by Trouble Free Test Kits
    Western KY
    36
    Its been running 24/7 for about 1 month. Not sure how long its been in operation if thats what you mean.
    20,000 gal. Vinyl
    How are you vacuuming it? Using a vacuum, with your filter set on "Waste", or something different?
    I tried hard not to do the above, since I hate the amount of water it wastes, and we live on an old street with no storm sewers (at the top of a hill no less, I basically have to flood out the street :<) but for the finer particulate, I couldn't find any other way to do it.
    Using the hose method with water to waste, I had no problem getting rid of it, as long as I went somewhat slow. Just let everything settle for about a day (turn the pump/filter off), and it should all vacuum up pretty nicely.
    Jim
    Western KY
    36
    I have been vacuming on filter for the same reason that you mentioned above (wastes too much water).
    Sean, from reading the link that you attached, I can use bleach instead of the overpriced pucks at the pool store?? Will it not discolor the liner? Do I need to brush the pool after adding the bleach?
    Great forum, by the way. I have learned more in the past day than I have in the past month trying to figure this stuff out on my own.
    20,000 gal. Vinyl
    Not Sean, but YES! bleach is simply another form of chlorine!
    It will not! Bleach is actually a less concentrated (5.75 or 6%) form of liquid chlorine commonly sold at pool stores (which is usually 12%) Ok, if you pour it in one place with the pump off, yes, but so will pucks or or dichlor
    Nope! just add the bleach slowly in front of a return with your pump running, of course, and let the pump run for a while to circulate. If you need to brush anyway, it will just help distribute the Cl faster!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
