Results 1 to 11 of 11
Thread: Normal daily FC Loss?
    Split from fc-loss-overnight-t67268.html
    Please start your own thread when you ask a question Butterfly
    And what would be normal daily FC loss for a hot sunny day with bathers ? 2 ppm ?
    In-ground 16'x32' rectangular, 3' shallow, 8' deep, approx. 76k Litres
    1HP Jacuzzi Magnum, sand filter, heat-pump, chlorine dispenser
    Taylor K-2006 test kit
    Up to july 2013: Cal-hypo 65% along with weekly tablets (2) of trichlor in dispenser
    Moving to: 6% bleach
    Montreal, Canada
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: FC Loss overnight
    2-3 ppm in the conditions you describe would be normal.
    Jeff
    Re: Normal daily FC Loss?
    I'm contemplating moving from Cal-Hypo to bleach.
    I have access to 2.85L jugs at Canadian Tire for a decent price ($1.19 I think).
    According to my pool calculator app, raising FC by 2.5 ppm for my pool (76k litres) takes 1.5 jugs.
    So, a sunny week would require 7 x 1.5 jugs = 10.5 jugs / week !!!
    Is this at all realistic ? I don't really care about the cost, it's the hauling of jugs / storage that'd be a bother...
    Montreal, Canada
    30,426
    What is your CH level now?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What is your CYA level and what test kit are you using?
    Jeff
    CYA is 40, CH is 200.
    I was using Cal-Hypo along with 2 trichlor tablets in a dispenser once a week until this week.
    That's when I got my Taylor K-2006.
    CYA is 40 and CH is 200.
    Should I continue adding trichlor tablets until I reach CYA 50 ? My understanding is that the more CYA I have, the longer the FC will last (although I'll need to keep the level higher) ?
    Montreal, Canada
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would go no higher than 50 ppm of CYA. You don't have a SWG do you ?
    Put your pool info in your sig, it will help us help you.
    Jeff
    30,426
    Using Cal Hypo is fine for your pool. Test and manage your water so it doesn't get above around 400 and you should have no issues.
    There's diminishing return on increased CYA levels. I would agree with pwrstrk's advice.
    Added signature...
    Is FC degradation a linear function ?
    I mean, for the same amount of sunshine, if I started the day with FC = 16 and ended at 13, would it have gone from 5 to 2 on the same day, all else being equal ?
    Montreal, Canada
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I'm not sure on that. Sometimes higher fc levels lower faster i think. Lots of factors come into play with FC loss.
    That's a good question for chemgeek, or the other experts.
    Jeff
    30,426
    It's not linear, it's a percentage.
