Results 1 to 7 of 7
Thread: water balance and TA/PH questions
    today's test results
    FC=2.5, CC=0, PH=7.8, TA=70, CH=240, CYA=35, water temp 78
    water balance is +.15
    so all is good....but since my TA is below normal recommended range of 80-100, should I increase TA or just leave it be? I did add some muriatic acid yesterday since the ph was pushing 8.0 and I guess that lowered the TA too.
    I am thinking just do nothing while water balance is in range?
    also another question
    when I do start raising the TA...I usually use baking soda......but that raises the PH.....then if I use muriatic to lower the PH...that lowers the TA....is there a better way?
    thanks.
    24K gal, plaster, concrete decking, cantelivered coping, 20 years old, raised attached stone spa - 1 1/2 HP purex triton pump, 3 yr old 48 sq ft Pentair DE filter with multiport, Polaris 380 w/pump, 2 yr old Pentair mastertemp 400k heater - live in southeastern PA outside phila.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: water balance and TA/PH questions
    Total alkalinity indicates the water's ability to buffer pH changes. If the pH is relatively stable, I would not fiddle with TA just to reach a target number. Your pool's pH is on the high end of the recommended range and will need to be lowered if it gets any higher. Muriatic Acid will lower both pH and TA as you have correctly surmised. If TA does get too low (say below 60) it can be increased with baking soda.
    Actually, baking soda has virtually no effect on pH.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I agree with Bo.
    Jeff
    Lots of conflicting info out there about baking soda also raising PH so thanks for your opinions
    30,414
    You should disregard any info you read about baking soda raising pH....it doesn't.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    + 1
    Jeff
    Butterfly's Avatar
    South Carolina
    10,045
    You can use the "Effects of Adding Chemicals" section, near the bottom of the PoolCalculator, to help predict results.
    You're done SLAMing when:
