Thread: CYA
    Wildcat's Avatar
    Jun 2013
    309
    CYA
    If I have every reason to believe my CYA is well over100, should I just do the diluted to save chemicals?
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: CYA
    That would be fine but since this is your first time with the test kit, I would do it normal then make adjustments on any subsequent tests. You have plenty of reagent so I wouldn't worry about your initial test.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
