Results 1 to 15 of 15
Thread: High Chlorine Level
    Oct 2011
    Chicago, IL
    113
    High Chlorine Level
    I have a high chlorine level due to slamming my pool. I also have a pool party tomorrow. What level chlorine is dangerous for swimming?
    Is there anything I can do to lower chlorine levels right now?
    I have a 35,000 gallon, sand filter, sunken above ground (so inground), vinyl liner, with an Aqua rite turbo cell SWG
    38,305
    Re: High Chlorine Level
    What are your CYA and FC levels? Generally safe up to shock level for your CYA.
    Oct 2011
    Chicago, IL
    113
    tc - 15-17ppm
    cya - 40-50ppm
    this is prob inline with shock levels per the chart. is there anything I can do in the morning (i.e. 10am) with chemicals to lower tc by 1-2pm?
    Or should I just start dumping water and refilling?
    Or do you think I am ok?
    I turned the swg off and took the pool cover off. Thoughts?
    Oct 2011
    Chicago, IL
    113
    The whole family is coming over to use my pool, i feel like such a jack*****!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What is your FC and what is your CC? If you have CC>0.5 ppm it can be irritating to swimmers. Per the chlorine/cya chart at 40 ppm cya the FC shock level is 16 ppm, so if you are below that you are fine.
    38,305
    Better to have a little much than too little. How are you testing? That TC range is not what i would expect if using one if the recommended test kits. What does the water look like?
    Oct 2011
    Chicago, IL
    113
    TC - 15ppm-17ppm
    FC less than .5ppm
    The water looks crystal clear. I am using the TF 100. I did the test 5 times because the second and fourth one was 15ppm.
    So you guys think I will be ok?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I think you are confusing the TC (total chlorine) with FC (free chlorine) and FC with CC (combined chlorine). TC=FC+CC
    FC is what the first part of fas-dpd chlorine tests. Assuming you actually meant FC, why such a big range (15-17)?
    38,305
    Ah, you mean FC is 15ish and the CC is less than .5 You could do the OCLT tonight and that could be passing all the criteria to stop SLAMing.
    You seem to be under the shock level, so you will be fine. Have fun and let them be impressed with the water quality. No one will even know the FC is high.
    Oct 2011
    Chicago, IL
    113
    I did mean FC, I have no idea. Two of the tests came out at 15 and the others were 16 and 17. Maybe im not adding the same amount of that powder each time. It says heaping mound, so not very scientific.
    Assuming it is 16-17, still ok?
    38,305
    The amount of powder does not really matter, as long as you use enough. If you add the drops too fast, they could be smaller and give different readings.
    Relax and have fun. I can almost guarantee no one will comment thinking the chlorine is high.
    Did you test the pH? (Even though it is inaccurate when FC greater than 10ppm)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How does your water look?
    If FC is still 16 tomorrow morning, you should be good to go for swimming since 16 is the SLAM level for cya of 40 ppm according to the chlorine/cya chart. If it drops much (more than 1 ppm), then you have something growing in your pool.
    38,305
    Already confirmed the water is clear. Really the OCLT is the last official step.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    oops, missed that
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by horseradish1
    Yes. With that high of a bather load, the FC will drop far enough below shock level that you will be fine for the party. Bring it back up in the evening to run an OCLT tomorrow night so you can verify the SLAM process is complete.
    Make sure that before your guests get in the pool, if anyone feels the need to slather on the sunscreen, they do it at least 20-30 min prior to jumping in.
