Results 1 to 11 of 11
Thread: Imminent install. How the heck?!..
    Jul 2013
    NH
    86
    Hi, folks. First time poster and soon to be new pool owner.
    My question is regarding skimmer installation and pool filling. First off, the pool is being professionally installed. From what I understand, after the liner is installed, the pool must be filled approx halfway BEFORE the skimmer, etc, is cut in. I plan on having my water delivered. How the heck is this done? Am I supposed to have the pool install crew here at the same time the water truck arrives? Then have the water dude fill the pool halfway, stop and wait for the pool installer to cut the fixtures in, then continue filling when he's done?
    I highly doubt the water delivery driver is gonna want to wait around for however long it takes the pool guy to do his thing. How does this usually work? Both the pool company and water company are 50 minutes away and getting them both there at the same time is obviously crucial.
    Mike
    18' Sharkline Oceanic
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    Use DE for your filter? DO NOT use anything but POOL GRADE DE!
    Re: Imminent install. How the heck?!..
    Welcome to TFP!
    Generally you want them there are the same time. Generally it takes several trucks of water to fill a pool, so there is normally time between trucks to cut the openings. If needed, the pool can be completely filled, and then the openings cut, even though that is not preferred. Cutting the openings doesn't take much time.
    In any case, both groups do this kind of thing all the time, and probably know each other, so it is usually fairly easy to arrange.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    The skimmer opening is cut after the skimmer is installed anyway so its really the return... and that is a 3 inch circle... pretty quick. I took my return out of my pool last night... while full. Lost a 1/2 inch but thats ok.
    -- Guy --
    Jul 2013
    NH
    86
    Thanks, guys. I figured that must be how it's done. Still seems odd to me though, from a "time is $" sort of way, but I guess there's no other way.
    About how long does it take the pool guys to cut in the skimmer and return?
    Mike
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    Jul 2013
    NH
    86
    OK, just called the pool water company, which I probably should have done initially. They confirmed what you guys said. They recommended I order the water through the pool company and let them make the arrangements with the water company to set up the rendezvous.
    Mike
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If they are skilled it won't take them long to cut skimmer and return in
    Jeff
    Jul 2013
    NH
    86
    Thanks, Pwrstrk. That's what the water company said. They do it all the time.
    Can't wait til this thing comes in! The pool was supposed to ship from Sharkline last Mon. As of Thursday, it still hadn't shipped. They were planning on doing the install this Mon, but obviously that isn't gonna happen. Oh well.
    Mike
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Do you have yourself a good test kit? I would also like to mention that you have everything you need on hand to get the water balanced correctly from the start. I've seen alot of questions like,pool just got filled now what? You don't want to mess up the first fill.
    Jeff
    Jul 2013
    NH
    86
    I have the Poolmaster 22270 kit. The pool comes with a kit as well. It also comes with a couple weeks worth of chems. Almost positive the water comes from the city's municipal water supply, for whatever that's worth. I'm familiar with water testing having owned many fish tanks over the years. I'm hoping that experience carries over to pool water. Once they give me the run down, I'm confident I'll be able to figure it out. If not, the forum is here
    Mike
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I'm not familiar with the pool master kit. If the kit that came with the pool are strips, they are not accurate enough.
    Jeff
    Jul 2013
    NH
    86
    Not sure what comes with the pool. The poolmaster kit uses drops.
    Mike
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
