Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Test kit arrived and the numbers are in. Alkalinity HIGH!
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    So my test kit finally arrived a couple hours ago. I read through the manual and went out to test the water.
    FC 4ppm (Pool Company said .5 - 1.ppm with Aqua Smarte)
    CC .5ppm
    TC 4.5ppm
    pH 7.8
    ALK 275
    CH 90
    CYA 53? (was closer to 50 than 60)
    So I'm thinking after reading the Basic Pool information that I'm in the range on everything but Alkalinity. Am I understanding correctly?
    Time for muriatic acid and then running a fountain to aerate the water to bring the pH up after lowering the ALK?
    27' Round X 54" Aqua Leader Sentinelle AGP, Vinyl J hook liner. 18,500 gal.
    Waterway 19" oval sand filter, US Motors EZBN25 1.0 hp 1.5 SPL Pump, BBB (Empty Aqua Smarte System connected, may use during vacation), Barracuda Zodiac 1500,
    Taylor FAS-DPD K-2006 Test Kit.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Test kit arrived and the numbers are in. Alkalinity HIGH
    Your first concern should be chlorine so close to the minimum level. You should make an effort to keep it closer to 6ppm.
    TA isn't a huge concern. It will keep pushing your pH up. If you stay on top of the pH and keep it down in the lower part of the range, your TA will fall over time without much effort. If you have a mesh cover, winter rains will help by replacing pool water with 0ppm TA rain water.
    If it becomes an aggravation to keep your pH down, you can follow the aeration procedure in Pool School and move it more quickly.
    30,432
    When you did the TA test, did you wipe the dropper tip every 2-4 drops of the R-009?
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    I thought since the Aqua Smarte had the mineral thing and the pool store telling me .5-1.ppm for chlorine that the 4.ppm would be good.
    The pool came with the solar cover and a winter cover which I haven't taken out of the box yet. Not sure what it is made of. I thought it was to keep water out?
    I'll have to re-read the information I guess. I thought the fountain/aeration was to raise the pH without raising alkalinity when the pH dropped from lowering the alkalinity.
    No. I did not wipe the dropper tip. Didn't see I was supposed to. Why is that?
    38,524
    Static can build up in the reagent and the TA drops may be smaller than they should be resulting in a higher result than reality.
    When you change your TA using chemicals (in this case, acid), it will change the pH, too. You do not want to push your pH below 7.2. So, you can add acid to bring your pH down to 7.2. That will also lower your TA, but it won't get it within range. As previously said, this isn't that big of a deal. Your pH will go back up more quickly because of the high TA, but nothing else "bad" will happen. Once the pH creeps up again, you can use acid to bring it to 7.2, and again, this will also lower the TA. If you want to make the pH go up faster so that you can use acid again more quickly, you aerate. I don't know of any reason to make it go faster, though.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Keep your FC level up some. It's at the min level for your CYA of 50.
    Jeff
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Thanks. I have another question after reading the pool schedule. I don't see shocking the pool on the list. So if my chlorine never drops too low I don't have to shock?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That's right. Keep your FC levels in range for your CYA level and you'll be golden. Only reason for shock levels is if you have algae going on.
    With the proper FC levels you won't have to SLAM.
    Jeff
    Butterfly's Avatar
    South Carolina
    10,045
    Have you found the PoolCalculator yet?
    With CYA of 55ish, keep FC between 4 and 9, and never below 4.
    Welcome to the forum
    You're done SLAMing when:
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Yes, I found the Pool Calculator. Also purchased the SimplePool app for my android that I read about on here. Both appear to be great assets!!! I just can't wait until the contractors finish the retaining walls so I can get the solar blanket off and get in the pool more. It's so muddy all around the pool right now I hate to even try to take off that massive cover without it becoming covered in mud! Should only be a few more days I believe. This site has a wealth of information!!!!! Thanks to all!
    Jun 2012
    Louisville, KY
    266
    Reference this for FC levels. It's the most important as maintaining your FC for CYA level is critical to keeping the pool sanitized. It's the FC/CYA chart.
    pool-school/chlorine_cya_chart_shock
    You MINIMUM is 4 and target of 6 for CYA of 50. Min 5 and target 7 for CYA of 60. You should never let the FC get below minimum or your asking for algae within 24 hours if not sooner. This is probably the most critical aspect of troublefree - the FC/CYA relationship.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Just keep adjusting pH when it rises and TA will go down all by itself. It's not harmful in the slightest to humans (you bathe in the same water and drink it) and your CH level is so low that scaling is not really a concern.
    Low FC is a concern.
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Thanks! I increased the setting on the Aqua Smarte so the chlorine should rise back up. Can I add bleach if the solar cover is on? Until they finish the retaining walls in a couple days, I really don't think I should take it off.
    Richard320's Avatar
    Jan 2010
    19,071
    Quote Originally Posted by brmommy
    You shouldn't need to add any. You will lose very little FC to sunlight if the pool is covered.
    But if you need to raise FC, yes, you can lift the edge and pour it in in front of a return while the pump is running.
    What is in the Aqua Smarte? If it is trichlor, you are increasing both your chlorine and your CYA. Your CYA looked fine at 50-60; I don't think you want it higher. Switching to liquid bleach instead of the Aqua Smarte will raise chlorine without affecting CYA.
    Jun 2012
    Howell, NJ
    977
    I just looked, and the Aqua Smarte says it uses minerals. You really should get rid of that, because it adds copper, which, when it gets too high, will cause staining and can turn your hair green.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jun 2012
    Rochester, NY
    247
    Hi brmommy,
    I was in the same place as you last year, new pool installed (24' Round X 54" Aqua Leader) and was using the Aqua Smarte Mizer Pacs to chlorinate. See my thread here: http://www.troublefreepool.com/need-...ks-t46924.html
    The Mizer Pacs are expensive and are trichlor which will also increase your CYA. You really don't want yours any higher. You should switch to using liquid chlorine if you can find it or regular bleach to chlorinate your pool. Don't remove the Aqua Smarte system though. I use mine when I go on vacation for a week. It raises the CYA a little, but I know to keep it a little lower in the beginning of the season to account for it. I than lose some when I have to drain for the winter. I actually cut the mizer pac in half, fill with trichlor tabs and then use electrical tape to seal it back up. Cheaper than buying a new mizer pac.
    Also, regarding your solar cover, I made solar cover hangers out of PVC to hold my cover, it was relatively cheap and easy. You can check out the thread here if interested: http://www.troublefreepool.com/homem...-s-t47666.html
    Good luck! This forum is a great place for us to learn. You'll be an expert in no time.
    Rick
    Installed June 2012 Aqua Leader 24ft Round AG Influence w/54 inch walls 13,500 gallons
    Cartridge Filter 100SF, 1.5HP
    Aqua Plus Smarte System - In for vacations, BBB all the way.
    Love my PVC Solar Cover Hangers
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Quote Originally Posted by rick6668
    Hi brmommy,
    So did you just leave in the original mineral pac? I didn't know if leaving it there would cause any issues. I was thinking like you mentioned of it being nice for the Aqua Smarte for when on vacation. Do the minerals in the mineral pac get all used up and then it becomes empty or does something remain that needs gotten rid of?
    I really appreciate the knowledge this site has!!!!!
  20. Back To Top    #20
    Jun 2012
    Rochester, NY
    247
    Hi brmommy,
    I took out the mineral pac and ran it empty. I only put the mineral pac in when I have to use the chlorinator as the mizer pac fits inside of it. I figured one to two weeks a year was not a big deal to run it. It's supposed to be replaced each season, but I will only use this one cause I need it for the chlorinator to work. Haven't had an issue.. not sure if that's a problem, I thought it would just empty out.
    Rick
