Results 1 to 7 of 7
Thread: SHOULD I SLAM ?
    Jun 2013
    Massachusetts
    23
    SHOULD I SLAM ?
    I just purchased my TF test kit and I'm glad I did. I took an initial test using the K-1000 for my PH and Chlorine. I also tested my CYA, which was very different then the readings the pool store gave me. I have a slight allergy growth on the walls of my pool, so my question is if I should SLAM it? for the most part the water is clear and the deep end is slightly cloudy. My Chlorine levels are at 2ppm and my CYA is about 70.
    Thanks!
    Jason
    Massachusetts - 30,000 Gallons, Inground, Gunite, Hayward Salt Water Generator, T-15 Cell, Hayward C3030 Cartridge Filter.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: SHOULD I SLAM ?
    Can you please post a full set of test results?
    You're done SLAMing when:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: SHOULD I SLAM ?
    If you have ANY algae growth-----you should SLAM your pool. 2 ppm is too low for your CYA.
    Sep 2009
    Greentown, IN
    914
    Re: SHOULD I SLAM ?
    If your pool is slightly cloudy, that usually indicates a need to SLAM. FC of 2 is too low for a CYA of 70... it should never go that low or you risk algae growth.
    Please post your pool information such as size, kind of pool, type of filter, etc in your signature line.
    It would be helpful if you posted your full set of test results as well as your pool information.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jun 2013
    Massachusetts
    23
    Re: SHOULD I SLAM ?
    Thanks! Should I turn off my SWG when I SLAM??
    Jun 2012
    Howell, NJ
    977
    Re: SHOULD I SLAM ?
    Yes, SWG off during SLAM.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: SHOULD I SLAM ?
    Quote Originally Posted by SLAM Process - Pool School
    If you have a salt water chlorine generator, chlorine tablet dispenser, injection pump, or Liquidator, you will still need to use another chlorine source for SLAMing. All of these devices are designed to add chlorine slowly and steadily over many hours. To kill algae or lower CC, you need to put in lots of chlorine all at once. The SWG, tablet dispenser, injection pump, or Liquidator can be very helpful in the follow up stages to maintain FC at shock level, but for the initial couple of chlorine applications, you need to use another chlorine source.
    If you use the SWG to help maintain FC at shock level, be sure to turn it OFF prior to the OCLT.
