Thread: Noisy Intex CS15110 Sand/Salt filter system
    I installed a Intex sand filter and saltwater system (CS15110) about 3 weeks ago and it seemed to be working fine. Over the last 4-5 days it has become very loud, almost sounding like a bearing is out in the pump.
    The pressure gauge over the sand filter still reads in the green and it is still circulating well, but the noise is a pain.
    Obviously I'd rather not replace the pump, but if I need to, then I can.
    Thanks for any insight.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Noisy Intex CS15110 Sand/Salt filter system
    Welcome to tfp, DODoc2009
    I would contact intex since the pump bearings should not be failing that soon. Many people have had fairly good success with intex customer support.
