Thread: air in pump
    air in pump
    My pump works fine in pool mode but sucks air in spa mode, so much that the heater will just cycle on and off. I've lubed the pump basket O-ring and replaced the Jandy O-rings. I'm thinking I must have a leak somewhere on the spa suction return line. What is the best method to pinpoint the leak?
    30,411
    Re: air in pump
    It is simply detective work. Start at the spa and work backwards towards the pump through every joint, connection and any other possible air leak source and you will find it. It's often time consuming but there really is no alternative.
    Re: air in pump
    Thank you for the quick response, can you think of anything else I should check before I start digging?
    Also, what exactly am I looking for? water coming out? or air hissing
    noises?
