Thread: Post vacuuming schmutz?
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    There has to be a trick here that I'm missing-
    How do you turn off the pump to take the vacuum cover plate off the skimmer basket and drain the hose yet keep the last of the schmutz in the basket and not returning to the pool itself!?
    I feel kinda stupid here....?
    22,553
    Re: Post vacuuming schmutz?
    I don't turn off the pump. I pull the hose off and then pull the vacuum plate off and then remove the skimmer basket with the pump still running. Even if you have to stop the pump to get the vacuum plate off you can restart it so that the debris gets pulled back into the basket ans then you cna remove it. The skimmer weir should stop the stuff from going back into the pool.
    Jan 2012
    7,367
    Hmmmm... it should but it doesn't seem to once the pump is off. That lil door just flaps open and shut with any splash of water.
