Thread: Can the DE Filter Hold the 3hp?
    Jul 2013
    Puerto Rico
    76
    I'm upgrading from a 1.5hp Hayward Super Pump to the Hayward Eco Star (up to 3hp).
    I will be keeping my Hayward DE3620 Filter.
    Now, will there be any problem when the 3hp motor runs at max rpm hence, pushing double the power the filter handles at the moment?
    Will the filter hold?
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    22,550
    Re: Can the DE Filter Hold the 3hp?
    The hp doesn't really tell you what you want to know. It really has nothing to do with how much pressure it produces.
    You need to know the maximum pressure it can produce. According to the website the cutoff is about 80 ft of head (35 psi). I suspect the max is about 100 ft of head (44 psi) so the filter will be fine with it.
    If there were any danger of it overpressuring any normal pool equipment they would have warnings all over it.
    Jul 2013
    Puerto Rico
    76
    Thanks Dave!
    I agree with you. If there was any danger, it would be all over it.
    Thanks!
