Thread: Salt water virgin
    Jun 2012
    St Pete FL
    45
    Salt water virgin
    Have a neighbor leaving town for work and is going to rent his house. Has asked me to take care of his in ground pool which is a salt water pool. I think it is pebble tec. I have no experience with cleaning, and testing salt pool. I haven't gone over yet to get the 411 on any of the equipment. So... not sure about type of generator or pump. Also do not know size or gallons yet. What other things should I ask about or look for when I do go over?
    Next question is do you use a different type of kit for testing the water? I do not think so but just want to check. I did see here where the ranges for each level is a bit different than chlorine pools.
    As far as the amount of salt in the water..there should be a readout on the pump or generator that tells me that number right????
    How do I know what is the normal amount of salt to have in the pool. I am guessing that is dependant on the size and type of pool finish??
    THANKS you guys always pull thru for me as I am sure you will again.
    5,000 gal Fiberglass paper cartridge filter, autochlorinator, BBB
    20,000 gal Pebble Tec paper cartridge filter, BBB
    15,000 gal Pebble Tec, DE filter, autochlorinator, BBB
    20,000 gal Pebble Tec, sand filter, BBB
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Salt water virgin
    Quote Originally Posted by lilpam14
    That is really nice of you, how long will you be doing this, rest of this summer?
    What test do you currently use? Ranges are a bit different. Do you know how he tests his water?
    Unless he has a leak and is constantly putting in fresh water you shouldn’t have to test the salt for some time. As long as the SWG is working, the pool has enough salt.
    I would talk with him about how often he adjustes his pumpr run time and SWG % run time. If he has it set in a happy place you won’t be doing much, if he is constantly fiddling with it you may be too.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    4knights's Avatar
    NE Kansas
    419
    Just a note so you won't panic later on. When you get a big rain storm the SWCG may show low salt for the first few minutes when turned on. It happened to me and I almost rushed to dump more salt in the pool. I drove to the HW store to get more salt and when I got back my lights were all green.
    The rain had diluted the pool some but not as much as I had thought, once the pump had time to mix the rain water and pool water I still had a good salt level. (I actually liked the new level better)
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Jun 2012
    St Pete FL
    45
    Thanks been out of town and out of touch. He is going to be gone for 10 months. I like the idea of not having to do much, but how would I know if it needed to be tested?
    Like I said a complete virgin at salt water but trying to read up.
    4knights's Avatar
    NE Kansas
    419
    I test water chemistry with my TF-100 weekly(give or take a few days) I test salt about every 2 weeks and a couple hours after the pump has been running after big rain storms.
    Recommend testing PH and Chlorine daily.
    Jun 2012
    St Pete FL
    45
    Thanks 4knights
