Results 1 to 10 of 10
Thread: Watching PB closely - some of his statements are scary!
    Jul 2013
    Saint Louis, MO
    24
    Since signing my contract, I have learned a LOT about pool construction. Thanks, TFP! What really scares me is what my PB says when I ask some questions. Here are some examples:
    Me- "I'm interested in a variable speed pump."
    PB- "Nobody uses those. They are too expensive & don't save very much in electricity."
    Me- "I'd like white LED lights."
    PB- "I thought the only reason to use LED was to get colors."
    Me- "LED lights use 80% less electricity & the bulbs last years longer than incandescent."
    PB- "Oh. That's interesting."
    Me- "The rebar you installed sticks into the ground. I'm concerned about rust & concrete cracking."
    PB- "It only goes into the gravel, not into the ground."
    Me- "Rebar should be completely encased in concrete."
    PB- "Oh. Maybe we can cut off the bottom ends."
    PB- "We hit your sewer lateral while excavating. I thought sewer laterals only went out the front yard."
    Me- "You knew that the main sewer line ran along the back of my property. There was a green flag there."
    PB- "I've never seen a green flag in a back yard before."
    Me- "How often should I wet the shotcrete?"
    PB- "Unless it's really hot, you don't need to wet it at all."
    I could go on & on, unfortunately...
    I'm watching him like a hawk...
    ____________________________________________
    18x40 ft shotcrete, 4-8 ft deep. Pebble Sheen finish. Coverstar auto cover. Hayward c4030 filter. Hayward H series 300k BTU. Intelliflo pump. Intellichlor IC40. Pentair Easytouch controls. Dolphin Nautilus robot.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,508
    Re: Watching PB closely - some of his statements are scary!
    Oh my!!!! Are you able to be there every min. he is there? Just think of the stuff you would miss or he does not do if you are not right there! SCARY!
    Good luck!
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Breach of contract due to incompetence?? *hopeful*
    Sounds like a nightmare in the making, err... unfolding.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Crazy question --
    Is this your PB's first pool?
    Maybe his first construction project?
    If it isn't either of the above, Ask him for names with addresses and phone numbers of the others that have used him for ANY project. If he can't give you any, find a way to get out of the contract with him.
    Off chance may be that he's kidding around with you. Up to you to find out.
    Jun 2013
    SpringHill FL
    415
    Wow
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Jul 2013
    Saint Louis, MO
    24
    I've seen 2 other pools he built, and a co-worker used him as well. My co-workers job wasn't perfect, but he was satisfied nonetheless. I think one part is that he knows nothing about energy efficiency, and that has been one of my goals (in spite of living in the land of cheap electricity). He builds pools a certain way & doesn't seem to know anything else.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by msm stl
    I'm not shocked at all.
    PB- "I like to install proven equipment. Those variable speed pumps haven't been around long enough for me to trust them."
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    jv92red's Avatar
    Mar 2013
    SoCal
    117
    Looks like you have Pentair EasyTouch controls being installed per your signature. Was that by your request or was your builder familiar with it? Hopefully when it comes time to install and explain that system to you your PB's head won't explode.
    15'x35' IG 16,500 gallons w/attached raised 18" spa continuous coping w/underneath spill and ledger stone wrapped, NPT mini pebble aqua blue w/2x pigment & abalone shell finish, 2"x24" travertine coping, 3x Jandy Color LED lights (2 in pool), Jandy Flo Pro 2HP VS pump, Jandy LXI (low NOx) 400K BTU heater, Jandy CL460 cartridge filter, Jandy AquaPure Ei SWG, Jandy Z4 automation with iAqualink and remote poolside PDA, 1,300 sqft Belgard Catalina paver deck with drainage, fire pit that matches the spa with travertine coping and wrapped in ledger stone, Elitewood insulated patio cover, Vinyl gates, back vinyl fence coming soon...
    TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Personally, I'm waiting for the next installment: PB's instructions for startup and balancing
    Aug 2013
    8
    Wow! Scary answers and false in content
