Results 1 to 12 of 12
Thread: My new pool!
    My new pool!
    Hi! Newbie here. I have been lurking for awhile. You have a lot of great info here. We have been meeting with PBs and got an estimate today. What do you think?
    16 X 32 vinyl sport pool
    said they put gunite in the bottom of the pool
    3 1/2 - 5 1/2 - 3 1/2
    SWG (mineral springs sanitation system)
    30 mil liner
    stained concrete decking 4' x 4' x 6' x 8'
    Hayward Super Pump
    Hayward T-Series Sand Filter
    1 skimmer - 2 bottom drain
    2 return lines
    separate designated cleaner line
    hydraflow step jet
    automatic overflow
    polaris 380 automatic cleaner
    automatic timer (do we need this?)
    2 lights - 500 watt
    stone coping
    single tier fountain
    I hope to update this post with pics of our pool build!!!!
    Kristy
    In construction!
    16'6" X 33 Lagoon
    13,000 gallons
    rock coping
    tile border
    textured/colored decking
    Tahoe Blue Pebble Tec
    2 Deck Jets
    SWG (Goldline)
    Legend II Cleaner
    1.5 hp pump (Duraglass)
    Sand filter with zerobrite
    Casey's Avatar
    SW PA
    10,438
    Re: My new pool?
    Hi 1Kristy1~
    Can't wait to watch your build! 8)
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Re: My new pool?
    Welcome and good luck on your new pb.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: My new pool?
    What size pipe did they specify. Check on two speed pump. I don't have stained concrete, but some people may chime in on whether or not it slippery when wet.
    Dave
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    Re: My new pool?
    Yes, you want a timer. The timer lets you set things up so the pump runs say 8 hours a day, or however long you want, instead of needing to manually turn the pump on and off each day.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: My new pool?
    Hi 1Kristy1,
    Welcome to the forum
    You're done SLAMing when:
    Re: My new pool?
    Thanks for the welcome!! We've already met with and chosen another pb and pool. lol Neither has specified the size of pipe. I'll have to check on that. I'll also have to check on the 2 speed pump. Thank you so much.
    We are around Atlanta and we have chosen Hilltop Pools. We have heard so many good things about this Pb.
    Here are the specs so far:
    16' 6" X33 Lagoon Shaped
    Sport pool 3' 5' 3'
    shotcrete/pebble tec (Tahoe Blue?)
    textured decking?
    1 300 watt light (going to change this to 2) Is this bright enough?
    tanning shelf 4 x 8
    inside bench 5 w/step
    swg
    1.5 hp pump
    1 skimmer
    3 returns
    dual main drains with valve
    we may add a heater and a fountain/bubbler?
    Thoughts?
    Kristy
    In construction!
    16'6" X 33 Lagoon
    13,000 gallons
    rock coping
    tile border
    2 Deck Jets
    SWG (Goldline)
    Legend II Cleaner
    Re: My new pool?
    Kristy,
    Congrats! Our pools are very similiar. We also chose a sport pool so that we could enjoy the entire pool and not just 1/4 of it. We were also undecided about the heater but figured it would cost more later to install. We found both the SWG and the Heater for much less on the internet then what the pool company quoted. We did negotioate for them to install both. Something to consider. Can't wait to see pic's of your build, enjoy the summer!!!
    Raquel
    In Construction:
    425 SF Free form (aprox 18 x 23) IG Gunite
    7ft spa with spill over
    1.5 HP Jandy Pump
    1400 Aquapure Jandy SWG
    AE2500 Jandy Heatpump
    Guest
    Re: My new pool?
    One tip, don't let them sucker you into the Mineral Springs Beginnings and Renewal. These are just a very expensive mix of salt, borates, and CYA. Use plain solar salt, add the proper amount of CYA (60-80 ppm) and then add borates if you want (there is a sticky on how to do that in the Chemistry 101 section).
    The Mineral Springs SWG is actually a rebranded Goldline Aquarite SWG.
    Jul 2007
    Northern NJ
    299
    Re: My new pool?
    Hi Kristy,
    Welcome to TFP!
    I don't have an inground pool, but I ran across a thread on another forum where members listed things they wish they had done, or not done, as the case may be. A couple of the things mentioned were the depth of the tanning shelf, contract provisions and locations of returns. I found it to be a good read. Here's the link:
    http://www.poolforum.com/pf2/showthread.php?t=8111
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Jun 2008
    Marana, AZ
    347
    Re: My new pool?
    I didn't like the timer that came with my pool; to set it, you flipped the switch and listened for the beep; one beep for 24 hrs, 2 beeps for 12, 3 beeps for 8, and 4 beeps for 6. It was difficult to make sure you got the "beeps" right, you couldn't break up your run time into two blocks of time per day, and there was no clock to choose exactly when you wanted the timer to go on and off. I went to Home Depot, and got one of their mechanical outdoor timers. It's very simple, and works well.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Re: My new pool?
    Thanks so much for the tips!! I am nervous because they are coming tomorrow to sign the contract! ACK!
    Forgot to mention that this includes the Kreepy Kruiser...From what I am reading maybe I should ask for the aquabot or buy one on my own...?
    Kristy
    In construction!
    16'6" X 33 Lagoon
    13,000 gallons
    rock coping
    tile border
    2 Deck Jets
    SWG (Goldline)
    Legend II Cleaner
