Results 1 to 8 of 8
Thread: Newbie pulling out her hair...again.
    Jul 2013
    New Orleans, LA
    4
    After problems with frogs, algae, broken saltwater pump, etc. I've finally refilled the pool I hope for the last time. The new saltwater system has been running for about 36 hours.
    I am waiting on my test kit but these are the levels with test strips:
    Free Ch - 3
    Ph - 8.4
    Total Alk - 180
    Stabilizer - 30-50
    Copper - 0
    Salt - 2300 (low but saltwater system is not reading low)
    These results with a test kit with drops:
    FC - 3
    Ph - 8.2
    What would be my next step? I am totally pool challenged.
    Intex Above Ground Oval Frame 18' x 10' capacity 2885 gallons
    Intex 1500 GPH filter pump
    Intex Krystal Clear Ozone & Saltwater System
    Intex Wall Mount Surface Skimmer
    Jun 2013
    SpringHill FL
    415
    Re: Newbie pulling out her hair...again.
    You should lower your ph and I would up your fc
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Adjust pH, definitely.
    FC is in the safe zone for a SWG, but I'd be more comfortable personally with a little more of a safety margin.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yep lower PH and raise FC up.
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    I hope you have really thick hair!........but hang in there and we'll help ya' fix it.
    Jul 2013
    New Orleans, LA
    4
    Thanks for the quick replies gentlemen. Now how do I go about lowering my Ph and increasing my Ch? With stabilizer (cyanuric acid)? I know...I am a pool dummy.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You lower your PH with muritic acid. To raise FC turn your SWG up a bit.
    Spend some time reading in pool school. Tons of good info there. It's a must read.
    Jeff
    Richard320's Avatar
    Jan 2010
    19,004
    Quote Originally Posted by hdleono13
    pH adjusts with acid.
    You don't need to worry about CH with a vinyl pool liner - there's no concrete to etch.
    pool-school/pool_water_chemistry
