Results 1 to 8 of 8
Thread: Opinions
    Opinions
    Ok, I just redid my deck with is 16.5x23.5..I had intentions of moving my pool from the other side of the yard to next to my deck. I had a friend over today who put a very good question in my head, why not put the pool on the back side of the deck. I know the deck could hold the weight, but has any one else done this?
    13500 gallons
    Intex 2650 Sand filter pump
    AG
    Re: Opinions
    I might be clueless here, or have insufficient information, but just I don't think I want to to be anywhere close when you decide to see if that deck (regardless of design) can hold just shy of 113,000 pounds. 56.5 tons. Plus the weight of the hardware.......
    Just Sayin.................
    24 foot AG Vinyl, 10 year old wall, 1 year old liner
    Hayward 240T Sand (free!)
    Hayward 1.5 hp pump (free)
    BBB just ROCKS!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Opinions
    I agree with sbn, that is a ton of weight and I highly doubt your deck was built to hold that much.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Opinions
    BIL put his on a purpose built deck, I never look real close at it so don't know how well built it is.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Opinions
    Defiantly don't put that on your deck unless it was engineered for the weight.
    Jeff
    Re: Opinions
    Thanks, was just a thought..the deck is only like 6" off the ground also..so not a high deck or anything, but regardless I will be putting it next to it.
    13500 gallons
    AG
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Opinions
    A 6 inch deck just means when the deck fails, you would have 6 inches of wood sticking up into the pool instead of a 3..4..5 foot deck.
    Good decision!
    My deck is only a foot or so off the ground, next to my 54 inch walls.
    -- Guy --
    Sep 2009
    Greentown, IN
    914
    Re: Opinions
    Good choice... I would hate to think what would happen if the deck failed while people were in the pool!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
