Thread: pH and SLAM question
    Jul 2013
    Southern Delaware
    71
    Almost done SLAMing the pool...before I started the SLAM pH was 7.3.
    I tested my pH today and it was at 8.2, FC was 28, CC 0...
    I realize that you cannot get an accurate reading with the test kits at such a high FC, but I work in a water laboratory and have some equipment that allows.
    My question is this. Should I add acid during the SLAM, getting it back down to approx. 7.5, or am I better off waiting until the SLAM is done?
    Will my pH lower as the FC decreases toward the target of 8, or will I have to help it out?
    Thanks... I look forward to your replies....
    13500 Gal. Above Ground. Vinyl. Hayward E-100 Highrate Sand Filter with Hayward Power Flow LX pump. Installed 2006.
    Feb 2008
    Denton, TX
    5,061
    Re: pH and SLAM question
    Until your FC is below 10, your pH reading cannot be trusted. Wait until it falls below 10 and test. Then you can adjust accordingly.
