Results 1 to 11 of 11
Thread: BBB and Frequent Travel?
    Jun 2010
    NE Ohio
    52
    I'm curious how you handle frequent "away" time from your pool using the BBB method (long weekends more often than not through the summer) when a house/pool sitter is NOT an option.
    24' round/52" deep Leisure Bay AG est. 13.5k gallons
    Hayward TS180 Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: BBB and Frequent Travel?
    I have a Liquidator which keeps my pool chlorinated for more than a week without any attention. The only thing I need done for my pool while I'm gone is to check the skimmer for leaves if we have high wind. I've had a neighbor add a few jugs of liquid chlorine to the Liquidator periodically when we were gone for more than a week.
    Once everything is dialed in, all the maintenance I do when I'm home is to skim the bugs and leaves off the surface and empty the skimmer basket.
    May 2013
    North East Ohio
    959
    I have a stenner injection system and I leave for 3-5 days nearly every week...just making sure I have enough chlorine in the jug for the pump.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Feb 2008
    Denton, TX
    5,061
    Some choose to simply use a tablet floater and place trichlor tablets in it. Now, if your CYA is highish, you may not want to do this.
    May 2013
    Virginia
    75
    I keep my CYA on the low side at the beginning of summer (25-30), and add pucks when I'm gone. About to leave for 5 days tomorrow morning and I'll toss some pucks in and bring the FC level up tonight before I leave. Last time we left for 4 days, and I came home to a clear, fairly balanced pool. Had to bring FC level up and vacuum some debris off the bottom, but it was good otherweise. My ph tends to slowly rise over time, so I make sure to push it down to 7.2 before we leave.
    10,000 gallon inground, gunite, 500lb sand filter. Brand new to this pool thing.
    Jun 2010
    NE Ohio
    52
    Thank you!
    Jun 2012
    Howell, NJ
    977
    The other option, if you have room in the budget, is to install a SWG. It uses electricity to convert salt into chlorine. They can be expensive, though.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Kymberly:
    In your situation, I would try the easiest method first...pucks in a floater or in an inline chlorinator if you have one. Of course, you will need to keep a close eye on the CYA level. This is the method I use when I go on vacation and it has worked well so far. Since most of your away time appears to be long weekends, you can remove the floaters when you return and save any unused pucks by wrapping them after they dry a bit and place them back into the bucket they came in. This will help mitigate the CYA rise. You can reuse the pucks on your next trip. The pucks I use are very slow dissolving and I could probably get about 4 long weekends in before these pucks dissolved down to a point where I needed to add a new puck or two.
    As an extra measure of protection, give the pool a higher than normal dose of bleach before you leave - say at the high end of the maintenance FC range for your CYA + perhaps an additional 1-2 ppm. I would test FC right before you leave and as soon as possible when you return and record the results. This should give you an idea of the chlorine demand while you are gone and may allow you to fine-tune your approach over time.
    This should work for you but, if for some reason it doesn't, then you can look into other more complex but effective options like a Liquidator, peristaltic pump, or SWG.
    Jun 2010
    NE Ohio
    52
    Quote Originally Posted by BoDarville
    Kymberly:
    I used the
    extra bleach" method this weekend and it worked beautifully! I don't think I've ever come home to such a pretty pool. No stains, no murky water, just sparkle clean. It rained while we were gone but it was also very cold (mid-60's!) which I think helped.
    My CYA is very low so I'm thinking of trying your puck idea - thanks for sharing! I would not have thought to rewrap and re-use them.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Backglass's Avatar
    Jun 2007
    Putnam County, NY
    139
    I am a very frequent business traveler (Platinum/Million Miler). I just fall back onto pucks in the skimmer when away and the family is home. If we are all gone, the tried and true "floater" gets me by until I return. I also monitor my CYA level so usually it's not a problem.
