Results 1 to 7 of 7
Thread: Taylor test kit question
    Jun 2013
    Northern NJ
    123
    Hi everyone. After hanging Round the forum for a month or so. I decided to purchase the Taylor test kit TF100. I should be receiving it tomorrow. After reading some online instructions, and watching some videos, it seem pretty intimidating to me. I mean, do I have to go out side with a calculator and a pad and pencil to record these numbers and then enter into the pool calculator ? I know for the forum that thus is "the kit" but I hope it's not as hard and time consuming as it seems. Thoughts , please?
    36,000 gal IG vinyl. Haywood pump and heater Hayward DE filter blue diamond robot. Hayward Aqua Rite SWG AQR-15
    duckhunter27's Avatar
    Jul 2013
    Dannebrog, Nebraska
    59
    Re: Taylor test kit question
    I just got TF-100 perty easy. The pool calculator is in pool school and yes it is a time saver just input your numbers .
    24ft x 52in Round AGP Heritage pool Aquamaster 19 in sand filter & 1 hp pump. Clear Solar blanket 12 Mil. TF-100 Test Kit. Pool filled June 3rd 2013 well water.
    22,553
    It's not nearly intimidating as it first seems. You'll get it down in no time and you'll wonder what all the fuss was about.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    There's a sheet in the kit to record readings. In a matter of weeks, you'll know the pool's appetite and will know how much bleach raises your pool how many ppm and so on. It gets really easy. Most of the time when you go out to run the full battery of tests, you'll be able to guess what you'll see. It's when it doesn't match your guesstimate that you need to worry.
    Wildcat's Avatar
    Jun 2013
    309
    I found the testing fairly easy, assuming I did everything right. I will gain faith as I do more testing and see consistency in the results.
    No record sheet in my TF100 kit received this week but I am sure I can make my own with no problem
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Jun 2013
    Northern NJ
    123
    Thanks for the help everyone. One more thing; is there a specific order to test. I.E should I test cya first ? Thanks
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Daily testing would be FC/CC, and pH.
    Monthly testing would be TA, CH, and CYA. CYA only if you have had a significant amount of water replacement, as in 6" or more.
    At least this is how I handle my own testing.
