Thread: How long before I can run pool heater after replaster job?
    My pool was replastered 2 weeks ago. It is crystal clear (no dust) and in balance. We are having a pool party on Sunday. Is it okay to use the heater at all? If so, what temperature should I not exceed?
    Thanks
    13,200 IG pebble sheen pool with raised spa and waterfalls, variable speed Pentair pump, oversize Pentair cartridge filter, Legend pool cleaner. TF -100 test kit.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: How long before I can run pool heater after replaster jo
    Bump
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    22,553
    It should be fine to run the heater. I wouldn't try to get it much more than 100F but anything under that should be fine.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    I'd run it whenever. What are you aiming for? 85, 86? If you had solar panels or even a solar cover it would be that hot by now anyway - unless you've been having weird weather or something.
    Thanks for the feedback. Now my pool will be crystal clear AND warm for the party.
