Results 1 to 11 of 11
Thread: Help a Newbie out?
    Jun 2010
    NE Ohio
    52
    Help a Newbie out?
    Day 4 of BBB Method and already much happier with the look of the pool! Stains are gone (knock wood!) and water looks sparkly and clear.
    (Under Pool Store tutelage our pool was intentionally dropped to 0 chlorine and 6.8 pH so the low start numbers were expected).
    But ...
    I can't get my chlorine up.
    Today's numbers (I have the wrong test kit but this what I have from mine)
    FC 0
    TC less than 1 (slight change)
    pH 7.6
    TA 130
    Water temp 71 degrees
    Yesterday FC was 1.5 and pH was off so I added 6% bleach solution and Borax per pool calculator. Pleased with pH but chlorine needs tweaking.
    I'm confused because I thought any TA over 120 needs adjusting but pool calculator didn't call for anything. It's entirely possible I'm reading this wrong being new. Thanks in advance for any help you can provide.
    We will be away Fri-Sun so my secondary question is how BBB users handle frequent travel?
    24' round/52" deep Leisure Bay AG est. 13.5k gallons
    Hayward TS180 Sand Filter
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Help a Newbie out?
    Worry about TA last, getting it down is a slow process and really only affects how fast PH moves. Keep PH under control and TA will take care of itself at your levels. Do you know what your CYA level is? It's important for determining where to keep you FC at. Also if you have low CYA then you can use pucks while traveling. Otherwise you have to have other strategies, for a couple of days with high CYA I'd bring the pool up to shock level and if available cover it.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jun 2010
    NE Ohio
    52
    Thanks for the prompt reply! I don't think my Poolmaster 5 Way test covers CY so I don't know that number. I'm thinking low only because our pool has run on low chlorine since opening in April. That's only a guess which isn't worth much.
    Jun 2012
    Howell, NJ
    977
    What did you use to chlorinate before switching to BBB? If it was any solid forms of chlorine, I would bet it is very high and that you may have some (invisible) organics growing in your pool consuming your chlorine. Since your FC dropped to 0, and your CC may be higher than .5, you will have to follow SLAM, linked in my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jun 2010
    NE Ohio
    52
    Quote Originally Posted by JohnN
    We used 3" pucks but the pool has been kept at 0 chlorine for the last month (stain removal). It stayed amazingly clear. I read the link for SLAM but it seems I can't SLAM because I don't have CYA numbers and have the wrong test? I need to study.
    Also I need to lower the pH I just raised? It was 6.8-7.2 and I just brought it up to 7.6. Still learning.
    I appreciate the info. I thought CC of 0 is what we want? Pool is not covered and gets direct sunlight most of the day. We have recently topped off with household/rain water. Appears clear.
    I really appreciate all advice. This is day two with my novice testing skills I'm going to see where we are tomorrow.
    I appreciate the link. Very helpful.
    Jun 2012
    Howell, NJ
    977
    You do want a CC of 0. That is not the only indicator of a problem, though. You really should get the recommended test. Per the SLAM article in Pool School,
    If you have algae, or the CC level is above 0.5, or the free chlorine (FC) level is zero, you should SLAM the pool.
    Your FC has been at 0 for a month, so I wouldn't be surprised if something has started growing.
    John
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You also need a good test kit to accurately test the CYA. CYA and FC work together.
    Jeff
    Jun 2010
    NE Ohio
    52
    We just got THIS test (ugh!) so it's kind of hard to justify throwing out that $$ and buying new yet. Is it worth buying an expensive kit this late in the season? For about 4 more weeks of pool time? 66 Degrees in Ohio in July(!) I wouldn't be surprised if no one swims again all summer.
    I'm going to check out the test kits linked in your signature (thank you!) .
    ETA: I checked out this link http://tftestkits.net/Single-Item-Tests-c6/ and see that there is an add on test for CYA. Could I add that to what I already have in order to get the results (ie use the test I have plus this add-on?) or is that a bad idea?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If your going to close in a few weeks maybe wait till next year.
    Jeff
    Jun 2010
    NE Ohio
    52
    Quote Originally Posted by pwrstrk
    Sent from my iPhone using Tapatalk.
    Thanks! It's hard to believe when it feels like summer is just starting but we've learned from past practice that keeping it open past Labor Day makes no sense and that's not far off. It looks great now - just a shame it's too cold to use it. Regardless of how much use it gets I need to "put it to bed" in good shape too.
    The link was a huge help. I have no problem making the investment once I read that they warranty their chemicals.
    Until we can get a better test:
    Last CYA test was on 7/9 and was 30.
    Liquid chlorine used since then in 12.5 and 6% concentrations, respectively.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yea you want to do that. If you can get a good level where your CYA is that will help alot.
    Jeff
