Thread: Installing New Hayward Aqua Plus & Eco Star Pump (Tips?)
    Jul 2013
    Puerto Rico
    76
    Hi!
    After a week of seeking advise on this forum and receiving very valuable input, I have decided on the equipment I'll be installing in about 2 weeks.
    The Pool:
    - Capsule Shaped 25ft by 8ft with a 6ft diameter Spa that cascades into the pool, 5ft deep and 3ft shallow ends (6,500gal approx., including spa).
    Departing Equipment:
    - Hayward 1.5hp Super Pump
    - Standard Timer & Circuit Breaker Box.
    New Arrivals:
    - Hayward Eco Star (I know it's probably "too much" for a small pool, but this is Puerto Rico and power is hitting $0.30 kW/h in less than a month)
    - Hayward Aqua Plus with Remote Control feature & Salt Cell
    What are your experiences with the Eco Star and Aqua Plus, either separately or together in a system?
    Appreciate any comments/tips!
    Thanks!
    J
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Installing New Hayward Aqua Plus & Eco Star Pump (Tips?)
    Use unions on the plumbing at equipment so it's easy to replace if there's a problem.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jul 2013
    Puerto Rico
    76
    Thanks and will do!
    Question to all:
    Is it worth to install a bypass to the Salt System Cell?
    J
